swapped tyres on the safari for a quiet run down to whirinaki next weekend
chevrolux wrote:
On a happier note, bought a pajero to be used as a whanau wagon/'pile the boys in and go for a mission' truck. Stock as a rock 88 paj with a 2.5L turbo diesel.
Going to give it a bit of s service.... Anything in particular people who have had experience with these think I should check?
meece4x4 wrote:keep up the servicing!!! they dont take kindly to being neglected, the 2.5's are notorious for cracking heads if cooked, so make sure your cooling systems in good nick , also they dont like revving ..
they are usually "dis'ed" by most people .. but they are surprisingly good wagons
meece4x4 wrote:chevrolux wrote:
oh and i guess you have already discovered that they require written notice three days in advance to exceed 100kph![]()
chevrolux wrote:Well after spending all week fixing my POS lux i thought I would treat myself and take it for a drive out to the beach. How silly was I!!!!!!!!! Busted the rear diff on the drive out there! Havent taken it apart yet as it's still sitting on the side of SH1. With any luck it will get stolen. So thats the second LSD I have busted in that. Time for some castor correction...
Dace wrote:chevrolux wrote:Well after spending all week fixing my POS lux i thought I would treat myself and take it for a drive out to the beach. How silly was I!!!!!!!!! Busted the rear diff on the drive out there! Havent taken it apart yet as it's still sitting on the side of SH1. With any luck it will get stolen. So thats the second LSD I have busted in that. Time for some castor correction...
dohl, have ya picked up the 6 pack off diffs?
chevrolux wrote:wheels got stolen. i supose thats what happens when you leave a truck on the side of SH1.
Whats my truck worth?
85 D/cab Hilux
Brand new maxitrac suspension with 50mm lift (leaves, shocks, shackles, u-bolts, bushes)
Runs a 350 chev through the hilux gearbox.
4.55 lsd's (rear is shagged, suspect just the pinion gear has fallen off)
If someone can give me a figure that would be much appreciated as I have a potential buyer but dont have a clue what its worth. Not keen strip it down as I am just so over the POS
85 D/cab Hilux
chevrolux wrote:yea i reckon. oh well. going to start over. this is just the last straw. sick of the pos.
liking the look of "4x4Matt"s truck. Chuck a solid axle under it and a 7m in the front and I will be away.
haydgq wrote:Nice looking Lux there, What are the plans for it once its completed.?? Is it your club truck and can you please measure the height of the Silverstones at a pressure you would normally run on the road. Cheers
suzuki1k wrote:Wellington Anniversary weekend was great! Had a blast in the Akatarawa Forest... thanks to all that came, hope you enjoyed it as much as I did.
Mudnuts and the new dent![]()
