Gen1, Gen2 A-arm swap?
motorhead
Canadian
Post by motorhead »
Looks like the arms will swap but not sure. Anyone done this so the ball joint flip can be done?
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
motorhead
Canadian
Re: Gen1, Gen2 A-arm swap?
Post by motorhead »
Swapped out one side today and seems to be fine. Will pick up other side this week sometime swap it out, shave upper bump stops, flip b-joints crank torsion bars (cv's to 25 deg) and have it alined. Getting ready for the new 32x11.5 Mudstars :D :D :D
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
motorhead
Canadian
Post by motorhead »
Gen 2 arms are longer. Am figuring what size spacer needs to be made, so far it looks like 4x12mm galv washers(thick ones) from Mitre 10 will do the trick and leave a little for the alignment.
Stock gen 2 arms on gen 1
With 4 washers
Let a little positive camber for the alignment guy to play with.
Lots of work to gain a few free mm
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
sprey
Post by sprey »
Lookin good as!, Bet you cant wait to give those new tyres a good run next week!
motorhead
Canadian
Post by motorhead »
Yep, will be talking with Roger on Friday to see if anything has changed. Watch other post for updates. Did you get your CVs done?
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
sprey
Post by sprey »
motorhead wrote:Yep, will be talking with Roger on Friday to see if anything has changed. Watch other post for updates. Did you get your CVs done?
Yeap both sides only 1 side was torn but the other side was on its way, so yea gotta play it safe.
New muffler next :D
NJV6
Post by NJV6 »
Yes, Gen 2 ones are longer. The first pic you show with the big camber - is that after the ball joint flip?
The ball joint flip gives you alot of unwanted camber.
The washers you put in - make sure those bolts are tight. They WILL come loose unless you either put two nuts on or some type of thread lock and longer bolts.
motorhead
Canadian
Post by motorhead »
Washers are only temp to find out the width of the spacer. Yes this was done after BJ flip. BJ's and a-arms will be double nutted
'Shit Happens"
?????NEXT?????
06 306 6098
021 02759048
binny
Post by binny »
I just picked up a gen1 swb and was looking at doing a bj flip now i no how awsum picks it will be a big help!
Return to “Mitsubishi”
