Fakey wrote:have you had the rim centres moved back a lot?
ding ding ding...
SMOKEY wrote:Nibz, everyone is trying to encourage you to "KEEP IT UP", don't they realise that if it wasn't up so much you would have more time to work on your vehicle and more money to spend on goodies.
FITZY.
FITZY.
petefj40 wrote:Bling bling! Nice!!
niblik wrote:too true.. have used chromoly heims to take the load compared to the std metal of the shaft only having a chromed surface, plus it'll be inline loadings on the locknut on the heim itself.. this combined with the extra long threaded section of heim recessed into the shock shaft too.. the shaft was approx 19mm in diameter, so heaps of wall thickness for thread purchase when threadin the heim's..
ultimately, time will tell..
flyingbrick wrote:Dont worry about the shocks failing near the joint. they have a ball in them for a reason. The only forces placed on that shaft will be in compression and tension (for lack of better words) and there will be NO lateral forces exerted on the shock or any part of the shock assuming everything is symetrical and nice.
And...![]()
you have done some awesome work there! I'm an apprentice turner and can really appreciate the work thats gone into doing that. I personally do not have the time or patience for anything like that....but I sure wish i did
KEEP IT UP... its working for you.
niblik wrote:why..., cos i feckin can...
petefj40 wrote:Might as well fizz up the body to the chassis then aye nibs?![]()
hosehustler wrote:Good point Pete, the body is now "hard wired" to the chassis there will be more vibration etc but ultimately a safer vehicle.
Good job on the tech side Pete you're catchin' on, and Nibz is merely being realistic for his needs
