maintance
maintance
put the safari in the shop for some work on the power steer box which recieved a big hit in the weekend ,
what also was found was cracking in the radiator fan blades water pump had a stuffed bearing, radiator third full of mud and aircon condensor is the same. even though ran water through the rad fins at clean up time the build up remained,
mileage is at 22000 kms and five years of offroad
- Sadam_Husain
- Angry bird
Re: maintance
Its called old age coxsy, sounds like you've caught the fan in time before the blades detached
can they rebuild the steering box or is it bent?
Re: maintance
they haven't heard back from the hydrolic people by the time i headed home tonight , the stuffed pump answered a question of a noise at idle i heard during the weekend
Re: maintance
the steering box is stuffed, got another for $300
the fan
the fan
- Andrew1706
Re: maintance
You don't know what you're missing till you drive a nissan...
Obviously a decent fan and power steering box
Re: maintance
Luckily you caught all that in time. Could've been expensive if the pump packed a wobbly, especially with the rad as blocked as it was!
I always kept a spare radiator (only cost me $20, plus $70 for a strip/rodding), and after a few muddy trips, (or 1 depending on how bad it was) I'd swap them over.
Sometimes it took over a week for the crap to soak out of the dirty one.
May do the same with the cruiser, buy a new rad, and keep the old one as a backup for after muddy trips.
- mudlva
Re: maintance
[/quote]kricky there years left in that fan
Re: maintance
if you think so,
you can have it
a spare steering box and rad maybe in the future
Re: maintance
i have owned 5 safaris now and all but 1 had fans exactly the same as yours, maybe i should change them
Re: maintance
All my Safari's were the same too, including the GU
Re: maintance
(Commin problem) Replaced my fan with new one from trade me,the old one was in shocking nick but still held together.To options in the tb42 engine so measure between the bolts if your replacing them.
89 SWB Patrol Lpg/petrol 5spd, body lift, spring lift,headers & high flow,Custom front bars 9000lb winch and 4x100w hella spots,custom rear bars and stainless fuel tank,Hankook 35/12.5/15x10 rims.
Re: maintance
common problem that no one mentions
Re: maintance
If you are careful you can take the radiator out without loosing much coolant. Something you get very good when doing winch comps as we normally pull them out each night for cleaning. To take it out should only require the removal of 2 bolts and 3 hoses to be undone.
Then the key is to water blast them from the back to foward. ie from the fan side so that you clean the mud (and small stones) out and not drive it in further.
When using high pressure it is very important that you are always at 90* to the fins so you don't damage them.
Then while it is out you can then clean the aircon condersor the same way (but without taking it out)
Re: maintance
all the bit done, bring it home tomorrow . then have service on my ute and wof to do, then the ford focus maybe the fj40 as well
Re: maintance
oh found these a must for your safari
http://www.trademe.co.nz/a.aspx?id=270634951
Re: maintance
Nissan Safari flayers
do they attach to the hubs, to be used for crowd control ???:lol:
LR110 ..... LJ50 project
Re: maintance
got the safari back , runs quiet now steers nice
Re: maintance
Know what you mean Coxsy. I have just done swivel hub kit, replaced bearings, fixed rear diff, new pulley bearings=quiet truck. Never heard the nissan so quiet. I can now hear the air swirling in the snorkel as it drives and give it some throttle.
Al
Al
Re: maintance
added an EFS enforcer steering dampner tonight via 4wd bits thanks
Re: maintance
had a crawl under the truck to check things, rear diff oil level plug loose , which is a bugger as was under water for 15mins and the diff end of rear panhard , nut was also loose, must of work free on flexing,
Re: maintance
hi does anyone know where to source the td42 fanblades from aftermarket? I'd try nissan but I'd hate to think what they would charge
