Which Calipers?
brakes-shocks-lockers-etc
turoa
Pyro Junior
Which Calipers?
Post by turoa »
Which calipers would be good for fitting on a hilux soild disk. I rang the wreckers about maxima calipers and they wanted $65 :shock: ... Each :-@ . So what would work well? I intend on buying 2 sets. 2 for normal braking and 2 for fiddle brakes. And how should I set up the levers? old hilux slaves?
JTop
Post by JTop »
Hi Turoa
I spoke to Andy Ward last week and he told me you can run fiddles through the same eyetem as your main brakes.
If you are running discs i suggest you run a pair of VH44 boosters to up the line pressure to the calipers.
J Top
De-Ranged
Post by De-Ranged »
Hey T are you going legal (certed :roll: )??
If you are there might be conditions you'll have to meet to double plumb the caliper.... talk to the certifier :(
If you decide to do the double calipers (I did on the rover after talking to my certifier :roll: ) use the clutch master off your lux 8) it'll run the single pot caliper good enough.... the booster Jtop is talking about is a good idea, I've been keeping an eye out for some at the right price 8) for the Rover (thanks Jtop :D )
Oh and see if you can talk the wreaker down I paid $40 for the pair on my last disk conversion :wink: another option is the Galant I think they are pretty much the same caliper
Cheers Reece
turoa
Pyro Junior
Post by turoa »
yea its getting certed. I might ring him and ask him about running them through the same system.
WACKO
Pyro
Post by WACKO »
was talking to a mate the other day who said you can t off the hydaulic line. brian howart would be a good person to aswell.
turoa
Pyro Junior
Post by turoa »
WACKO wrote:was talking to a mate the other day who said you can t off the hydaulic line. brian howart would be a good person to aswell.
I was sure that you had to run them through a sperate system too. I'll give the certerfier a ring tommorow
