rokhound wrote:Fakey wrote:Why do you bother with the
rotor spacers? Whats wrong with the original IFS rotors that are made to fit the IFS calipers/hubs? Arent they the same size an vented?
You have to modify and remount the Caliper to do that and you have to redrill the rotor for the wheel studs (thats the way I have done mine). I believe Tim's reasoning was to be able to able to use all factory parts that are readily available.
You're spot on with the reasoning Rock, and proved the point last year when I destroyed the radius arm and shocky in the middle of the bush behind Ikamatua, left the truck in the bush went to Westport, borrowed a radius arm off Flag and a nissan shocky from nuts fitted (mounted upside down) back in to the bush the next day and drove it home like that to Chch, if they were all custom parts getting mobile again is a bigger problem.
As for the IFS rotors they are smaller in diameter than a normal hilux/prado rotor, they can be used with a smaller simpler spacer but they don't make full contact with the brake pads so can't be certed, as rock says major mods to factory bits are needed.
As for the hubs the Aisin ones are far superior in strengtgh to the other listed brands, keep looking or put a wtd ad on TM, in fact there's a front and rear axle on there at the mo with aisins that is being parted out, seen it a few days ago
http://www.trademe.co.nz/Trade-Me-Motor ... 250094.htm
When are we going to get an update on your build Grant
