surf Auto NO GO
MO
surf Auto NO GO
Post by MO »
Hi all, managed to stuf auto g/box in my surf at the weekend, local suops want 3 - 3.5k to repair it, are they very hard to repair or do i find a used 1. or even convert to manual.
spanky
Post by spanky »
what mtr is it?.i have a v6 auto i want to get rid of .
vaughan
MO
Post by MO »
3l diesel 1kz??? dont think they are same? thanks
SupraSurf
Post by SupraSurf »
Check the Trans codes under the bonnet both those autos may actually be the same should be A343F or something close
spanky
surf auto
Post by spanky »
tha code for my v6 auto is A343H on the chassis plate. if is same and you are keen let me know as it is on trade me at the moment.
vaughan
MO
Post by MO »
just been out to garage it's A343. if the diff between the H & F dont matter im intersted.
MO
Post by MO »
SupraSurf
Post by SupraSurf »
Umm not sure on the H v F I'll have a nose around... brb
SupraSurf
Post by SupraSurf »
OK what it looks like is the difference is in the transfer case, one is most likely got an electric drive for selection the other maybe hydraulic or vacum
You can probably use the auto and change either the transfer case or the 4wd select and away you go..
krawlr
Post by krawlr »
f is usually from a turbo diesel and the h is from the v6 i think :scratch:
oldblue
Post by oldblue »
Prado KZJ 71 Auto 3Lt = A343 F
U-BOAT
Post by U-BOAT »
suprasurf
yeah you're pretty much spot on there suprasurf. from what i've read the only difference is the transfer box. The F box is electric drive for the selection and chain driven and the H box is hydraulic. the main gearbox is used in toyotas, isuzu's and even jeeps in the states.
MO
Post by MO »
thanks for all the help an info guys, Vaughn you still want to sell yours? be down on Saturday if thats cool?
Maurice
4wd; A money gobbling, divorce inducing hobbie! "and I love every minute of it!!!!"
Return to “Toyota”
