This is a system that controls the power distribution to the glow plugs in order to improve the starting performance of a diesel engine. It contributes to a clean-air environment by supplying power to the glow plugs even after the engine has started to thereby improve ignition performance.
OK now what about the GREY box below the radio inside the dash. It was bolted to the RHS of the internal steel frame.
It seems to be the unit which emits the "BEEP BEEP" when I go into reverse............................does it do anything else? What does removing it achieve?
its the roadrunner device
just pretend you're Wile E Coyote and you'll be right dude
if you get that little black box wet the truck starts funny and the glowplug lite does really random flashes i covered my will sealant after I dryed it and hasn't played up since stupid place to put it under the seat! well guess thats where your is located
flyingbrick wrote:nah mine is behind plastic pannel to right of gas pedal
When you do the cab swap, make sure you relocate it up high under the dash, but orientated so the plug is at the bottom. We had it upside-down originally and when it gets wet, it fills with water and it won't glow for starting.
