Got my throttle cable sortened. 12" shorter on the outer and 10.5" shorter on the INNER so that the travel is longer. Not impressed. Cable end was poorly formed and too big so i had to do lots of filing. Was late. Cost me 75$ (I might go into the snake shortening business... seems like easy money)
Thankfully I got the lengths bang on correct. Pedal/ throttle movement is perfect and there is adjustment left each way:mrgreen:
Thats all the major controls connected
Bought Vvega's old hoses and bends to pumb in the radiator and started fitting those. Its not quite as easy to route them under the cab as theres not a hell of a lot of room under there past the exhaust.
I mentioned earlier that I had some sheet metal disks plasma cut to size. I riveted those over all unused grommets and holes in the inner guards and cabin.
and then undersealed everywhere that wont be touched with a welder later.
I cut some more out of the body to lower it down.. still a little more to do. Gawd its going to sit down on there nicely.
far better than expected.
Last night my aluminum radiator arrived at my olds. Brackets to secure it onto the back of the cab are being made right now by collins profile cutting (hamilton)
The radiator is made for an RZ supra. I sat down with a calculator and basically worked out the volume of all readily available radiators (to fit jap cars) and grabbed the largest. I had credit at this particular store which meant I couldn't go elsewhere. Paid way too much for it. Guess i gotta take the good with the bad
Core size is 400x738x50 compared to the stock GQ's 460x740x35. Hope its OK sitting back behind the cab there with just electric fans on it. The factory radiator was absolutely screwed and buying a new steel replacement was more than this ali unit hence the upgrade.
So..
A little more wiring
rad hoses in
rad mounted
brakes bled again
a little more trimming
a bunch more holes drilled and rivnuts fitted
then its off to the welders to be finished. About bloody time
