rear springs for RUF 410
hey all, any ideas on what i can use for my rear leaves. iv done ruf and want to balance out the back for height. or should i cut off the mounts and drop them down 2"??????
DIRTY OLD HILUX
022 519 7700
022 519 7700
Re: rear springs for RUF 410
mix and match , 2/3 inch lifted rears , mazda 323 , feroza , carry , swift springs. any thing the same width as a zuk.
Should be able to come up with some thing slightly longer that will work.
Where are the pics of the RUF??
LR110 ..... LJ50 project
the back is sitting up a little cos of my driveway so about 50mm lift is still needed.... i like the way its sitting like that
poor mans lift park on a hill
DIRTY OLD HILUX
022 519 7700
022 519 7700
- mroffroader
Holy shit man how is that connected to the chassis
80 series tow bus towing a redneck ass vitara
hey chrome did i met you up at woodhill one sat lent you a spanner
na coxey iv never been there mate. and mr o its gonna be welded strait on with a couple of lap plates on the underside
DIRTY OLD HILUX
022 519 7700
022 519 7700
mroffroader wrote:Holy shit man how is that connected to the chassis![]()
its only tacked together when its done properly itl all be mint and the chassis will be capped off , its only like this so i can trailer it to work
DIRTY OLD HILUX
022 519 7700
022 519 7700
ok then there a snap type truck out there
hahaha two bogun machines he musta been from out west
DIRTY OLD HILUX
022 519 7700
022 519 7700
shackle angle at the front looks terrible.
What rear springs have you used up front?, dosn't look like they are longer at all.
How many mm of chassis extension? from what ive read on outers any more than about 60-100mm and you start fouling the steering and the shocks wont line up.
can all be changed easy what angle do the shackels need to be?? i just made them the same as they were and the shackle mounts have only been moved about 60 mm foward. the springs are rears off a 413 so the diff is foward by only 15mm just enough to clear the tyres from the firewall
DIRTY OLD HILUX
022 519 7700
022 519 7700
angled forward about 15 to 20 deg, bottom further forward than top, bout the same as it was before the extension. might have to shorten the shackles abit to get it right.
sweet il have a play round with shackle lengths to sort it cheers dude
DIRTY OLD HILUX
022 519 7700
022 519 7700
scratch that imgonna cut out the round crossmember and move it back till its all good about 45mm i think then il fizz it all up and weld on some towing hook mounts at the same time
DIRTY OLD HILUX
022 519 7700
022 519 7700
- mroffroader
Stu, you are ghetto fabulous
so badass i fill my radiator from blak creek yo
DIRTY OLD HILUX
022 519 7700
022 519 7700
- mroffroader
chur! *wipes nose down arm loudly*
needs a confederate flag .
Booty but looks like it should work sweet.
did you sort out the rear springs to suit the RUF?
the flags in the roof of my garage and ithink il just leave the rearfor now. il look for front shockies first, is it commie wagon ones i need??
any suggestions
im gonna remove the guards too i think and flat fender it then chuck a bull bar on that chunk of steel i welded on
any suggestions
DIRTY OLD HILUX
022 519 7700
022 519 7700
got abit excited after goin up to the rally in napier and chopped the front off my zuk.now i got some serious work to do
likethis
likethis
DIRTY OLD HILUX
022 519 7700
022 519 7700
- Sadam_Husain
- Angry bird
chrome wrote:got abit excited after goin up to the rally in napier and chopped the front off my zuk.now i got some serious work to do
Your new Father inlaw been giving you ideas Stu
hey I'm probably a bit late in your thread but are you going to put some shackel stops on those front springs to stop them inverting, if they are like cruiser ones they flip back under with a good punch into a bank or something solid?
yeah i might do but im thinkin later on to run coil front and leave the rear leaves
DIRTY OLD HILUX
022 519 7700
022 519 7700
- Sadam_Husain
- Angry bird
So what are you planning to chop off the front?
that bars been shifted back about 50 mm and the tube crossmember has been removed,
DIRTY OLD HILUX
022 519 7700
022 519 7700
- skid
- Tyre Man
amazing how the shape of a truck can change after someone goes to a trial to watch
i hear ya, im still tryna decide whether to scrap that poo galv cage and start over
DIRTY OLD HILUX
022 519 7700
022 519 7700
chrome wrote:i hear ya, im still tryna decide whether to scrap that poo galv cage and start over
YESSS WTBS could probably build a better cage than that
got a pipe bender if ya want to borrow it for suitable reward.....
pedro
