then I will start on the tube work for the sides and top.
I am by no means an expert welder but I think the welds are going to be plenty strong enough and look OK. Whats your opinion?
A bit anoying when you know that the welder is at its maximum capibility though. (240V, 180A at its highest settings running 0.8mm wire)
Once i get all ground down and the tube on it will be sent to the sandblasters so i have a nice clean surface to paint.
anyway, little chat, lots of pics......
Tacked up
Bottom tacked up
Inside tacked up
Me welding up the side
The side welded up
Side ground down. This is what i am going to do to all the exterior welds
Two front plates welded together
Me welding in the support tabs
Support tabs again
All welded up ready for grinding
Inside finished and ready for a clean up
