mig gas what would you recommend
aroma
Post by aroma »
right bought 140 amp single phase mig today $600 from smith city and was wondering what gas I should use?
have used argosheild in the past but am trying to keep cost down renting would be quite expensive and was looking at their throw away bottle but don't know how long they will last anyone used them?
so got a small coil of flux core to play with but not liking it big time
thanks in advance
Warren
ClassicCruiserSpares
Re: mig gas what would you recommend
To get good nice welds you really need to use gas ive always used argoshield, i used gasless migs before to try them out and didnt find it very succsessfull.
chrome
Post by chrome »
bite the bullet and use gas. get rid of the flux core and run a small diameter copper coated wire and run argoshield with it. or you can run it with c02 and put up with the splatter but its more cost effective
DIRTY OLD HILUX
022 519 7700
niblik
Post by niblik »
co2....
mike
Last minute Mike
Post by mike »
C02 for sure, and your right renting gets expensive especially when you have a gas set as well. but $11 per month for a c02 bottle aint bad. you can use the soda stream bottles like my bro does. but he has a real small mig.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
tallsam66
Post by tallsam66 »
You can use a CO2 extinguisher as a bottle...you just need to get it tested & fit the right valve & regulator.
haydgq
Post by haydgq »
tallsam66 wrote:You can use a CO2 extinguisher as a bottle...you just need to get it tested & fit the right valve & regulator.
Yea they work good, But I upgraded mine to a 6.3kg bottle as i was using the co2 extinguisher sized one to fast eh, I own my 6.3kg bottle and its only $60 to fill each time and lasts a while for the weekend warrior.!
rokhound
Post by rokhound »
I paid about $300 for my Co2 bottle, brand new and full from Asko gas. Costs $32 for a refill and lasts for about 1/2 - 3/4 of a 15kg roll of mig wire.
As an aside I just got a 15kg of non copper coated wire on trade me for $45 delivered to the door.
aroma
Post by aroma »
hurmp
mite have to try this co2
anyone go one i can try ............niblik?????
haydgq what was the cost to buy a bottle ? thats been answered already
and the flux core was only a trial but does get me going thou
juz
Post by juz »
Just bought a 5.8kg bottle of Co2 $350, I find piss all difference between co2 and argoshield, although I mainly only work with .8 panelsteel.
tallsam66
Post by tallsam66 »
My brother uses a 5kg extinguisher bottle....ive only just got it for him so dont know how long it will last yet.
Dace
Post by Dace »
I need a bit of advice, when I bought my Mig, I was also given an Argo-sheild bottle, but I don't actually have an account with BOC, so am not paying rental :twisted:
My question, how can I get it filled? with out gettin snapped :?
juz
Post by juz »
grind the numbers off and repaint silver/ get filled with Co2.... good score!! Old boss went and did botttle swap one day and came back with two! :D also a good score
tallsam66
Post by tallsam66 »
juz wrote:grind the numbers off and repaint silver/ get filled with Co2.... good score!! Old boss went and did botttle swap one day and came back with two! :D also a good score
Dont grind the numbers off...if its been tampered with they probably wont fill it...it must have been pressure tested every5 yrs...last thing you want is for it to fail..... & they do fail from time to time.
2MEKE
Post by 2MEKE »
Dace wrote:My question, how can I get it filled? with out gettin snapped :?
If it's in test take it to Supagas...they'll fill it
Edit: ....just saw your location :(
1rugger
Post by 1rugger »
i brought a new argoshield bottle from a welding shop on annex road here in chch for $500 and it's $45(i think) for them to fill it. previous to that i had co2 which worked well but welds weren't as nice as with argoshield and cost me more to fill. also tried the small disposable one's and they where nothing but a waste of time and money.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
darinz
Post by darinz »
At the cost of argoshield why would you stuff around with Co2?
I run a big bottle (about 1200mm tall?) and at $140 to fill it lasts for so long that the rental is normally more in the long run. One bottle did a complete new chassis for my GQ, including new deck and modified rollcage and a complete rollcage for a Suzuki.
And then if using Tig on steel can just swap it to that and save the Argon as that really is expensive. (well that is the plan as the Tig has only just arrived)
Have to agree that flux cored is crap. Get better weld with a stick!
Return to “Tool Shed”
