Best tyres for sand.Without modifications.
- Driver/Navigator
Hi guys,
Im a newbie to the site,and to 4wd. I do a lot of diving around Wellingtons the south coast(devils gate etc..).I have a Toyota v6 surf. I dont really want to modify the vehicle yet as at the moment it is the family vehicle as well.So keeping this in mind I would like to know what tyres are best to get me through the sand Without getting stuck?.As this would greatly extend my range when driving around the coast.Thanks
Re: Best tyres for sand.Without modifications.
tyres with the least amount of void in them, eg ht (highway tyres), eg road tyres, so dont bother buying any
Have a chat to Rob .... his details are here http://www.offroadexpress.co.nz/marketp ... xxis-tyres
turoa wrote:tyres with the least amount of void in them, eg ht (highway tyres)
just out of interest.. why is that? Do mud tyres just dig holes?
in short YES and very fast too.
its hard to beleave but bald road tyres are the best
- rangimotors
buy yourself a compressor and let the tyres down a bit, it will make them work far better in the sand. Keep a spade and a couple of old sacks in the truck just incase.
yeah i was under the impression it was all about tyre pressure that got ya through the sand, drop em down to 15psi or lower, i geuss balder the better to, sand scares the shit out of me
- Sadam_Husain
- Angry bird
rangimotors wrote:buy yourself a compressor and let the tyres down a bit, it will make them work far better in the sand. Keep a spade and a couple of old sacks in the truck just incase.
Yep like Dave said let your tyre pressures down (lots), that probably makes a bigger difference than what sort of tyre you've got on
- Driver/Navigator
Cheers for the tips guys...I wanna get a set of tyres just for the coast,So bald road tyres are the go? How about tyre width,am I able to get wider ones that will fit on without mods?I see some guys driving straight over the sand no problem. I always stick to the hard ground but want to be able to drive on sand too.I have been told to drop pressure and to take old carpet just in case aswell.It would be all the more better if I could avoid getting stuck alltogether,because that just eats into my divning time.
Will get hold of rob too.Cheers
wider tire you have the better. would be awsome to get hold of some of those paddle tires the icelandic people use for the sand dune driving.
- skid
- Tyre Man
local buoy wrote:I see some guys driving straight over the sand no problem. I always stick to the hard ground but want to be able to drive on sand too.I have been told to drop pressure and to take old carpet just in case aswell.It would be all the more better if I could avoid getting stuck alltogether,
south coast can be a dangerous place on your own
and even more treacherous if ya go on your own
do not under any circumstances drop down to the sand if you havent got any mates with vehicles with you to recover you if it turns to shite
salt water kills vehicles when the tide comes in after you get stuck on your own
trust me, it aint worth it
- Sadam_Husain
- Angry bird
Com on you've got some pics of your old 45 on windy bay havent you?
- Driver/Navigator
skid wrote:local buoy wrote:I see some guys driving straight over the sand no problem. I always stick to the hard ground but want to be able to drive on sand too.I have been told to drop pressure and to take old carpet just in case aswell.It would be all the more better if I could avoid getting stuck alltogether,
Yeah cheers mate,I do go alone often, but up untill longbeach you dont really have to drive on sand.So thats where I stop.It would be awesome to be able to get up to cable bay.Wellington being Wellington means the wind stops us from taking the boat out often.....So the next best thing is the surf.
i have a 2.8 diesel surf surf which is pretty gutless and i run 31x10.5 all terrains round there on 20 psi, any smaller than that and i just sink into the softer sand
i hope this helps
cheers sam
i hope this helps
cheers sam
pos nissan patrol
Ln106 single cab
Ln106 single cab
I have had good results "dare I say it" with some Hankook RT01's which are mud tyres.
Aired down to 15psi they had a huge footprint.
The side walls were very flexable.
They were 33 x 12.5 .
And I have a heavy truck...LWB Square Prado.
Used to go all day at Muriwai in the soft stuff. And get further than those with "less agressive tyres"
But I think the combo of Auto and floatation type tyres helped.
As already said, dont travel alone on the beach... Once in the tide...kiss yah truck goodbye.
Calvin
Calvin
- rangimotors
just to add and i''m sure its obvious but we do funny things when we panic but if you do start to get stuck do yourself a favour and DONT plant boot or you'll just dig yourself deeper.
If your a little stuck get out and have a look, you can usually help yourself out with some wood, or carpet/sacks, spade etc etc once your bellied down to your chasis your pretty much stuffed.
- hilux andy
- Driver/Navigator
As people have said ,let some air out the tyres you wont believe the difference
- Beer_Cruiser
If you wait till low tide you can drive on the nice hard sand down by the water......
- Driver/Navigator
Cheers for all the help guys,Ill see how I get on with just letting the tyres down,and will let ya know how I get on.Of course Ill take spade,carpet etc.. will try not to dig myself into a big hole if I do get stuck... and will go round with another mate and his hilux.
X2 for the hankook muds. Got some 33s with almost no tread left on them and they are awesome in the sand!
you should post up here when you go out next, im sure lots would be keen to join you for a drive/fish/bbq
99 pajero exceed 3.2
- Driver/Navigator
basics wrote:you should post up here when you go out next, im sure lots would be keen to join you for a drive/fish/bbq
Yeah good call,will do mate... at the moment the forecast is not looking all that flash on the south coast for this weekend.
- Sadam_Husain
- Angry bird
local buoy wrote:Yeah good call,will do mate... at the moment the forecast is not looking all that flash on the south coast for this weekend.
We're all up at William Hamiltons fixing his truck and cleaning out all his piss this weekend.... you should have watched the threads and popped around to Malcolms and Debs Beer Bach around the coast a couple of weks ago and met everybody
- skid
- Tyre Man
Sadam_Husain wrote:local buoy wrote:Yeah good call,will do mate... at the moment the forecast is not looking all that flash on the south coast for this weekend.
We're all up at William Hamiltons fixing his truck and cleaning out all his piss this weekend.... you should have watched the threads and popped around to Malcolms and Debs Beer Bach around the coast a couple of weks ago and met everybody![]()
I can see it now, a truck cruises up, out hops a newbie, introduces himself, then 2 weeks later when he next catches up with everybody, he has to do it all again, coz nobody remembered who the hell he was, least of all the long haired hippie who had to prop himself up all night, before stealing somebody's bed
- Beer_Cruiser
skid wrote:Sadam_Husain wrote:local buoy wrote:Yeah good call,will do mate... at the moment the forecast is not looking all that flash on the south coast for this weekend.
I can see it now, a truck cruises up, out hops a newbie, introduces himself, then 2 weeks later when he next catches up with everybody, he has to do it all again, coz nobody remembered who the hell he was, least of all the long haired hippie who had to prop himself up all night, before stealing somebody's bed![]()
Debs mum said he was the nicest drunk she has ever meet...
And he helped with the dishes
- Sadam_Husain
- Angry bird
Yeah I sort of thought I might have had bit of a sway on
Sorry if I broke any dishes
- Driver/Navigator
I got up to cave bay on Saturday..let tyres down to 20psi and the truck got through all the sand with only 1 minor hiccup.I had to navigate around a protruding rock,where the tracks are on a lean.I slid off track ended up in the soft stuff.Reversed,went forward and she pulled through ok untill I got back on track.Was well impressed with the ol truck.Maybe I dont need the big tyres after all? Might look at getting a lift for more clearance.
- tara13
Who's beer batch .....
