20th/21st March
worzel
20th/21st March
Post by worzel »
Just swaped my 3 inch lifted coils for 4 inch and my 33s for a set of 35s
Noticed when i picked the truck up with the fork lift the brake pipes are tight so will have to put some longer ones on
tallsam66
Re: 20th/21st March
Post by tallsam66 »
worzel wrote:Just swaped my 3 inch lifted coils for 4 inch and my 33s for a set of 35s
Pics please :D :D
worzel
Re: 20th/21st March
Post by worzel »
Will try and get pic for you Trev in the week
fj40
Re: 20th/21st March
Post by fj40 »
well only jut got my trailer finished :roll: after getting it off motorhead afew months ago :oops: just gotta put sum paint on it then its all ready to carry this
and the trailer
its not how big the 4x4 is its how angry the diver is
Fakey
Re: 20th/21st March
Post by Fakey »
Headed round to red rocks for the first time last night cos I finished work at 4pm (early for me). Pretty nice night for a drive. Had a bit of a play on the little hill climbs then found a couple of guys in a standard terrano with a flat tyre no tools an a padlocked spare :roll:
Luckily for them I had plenty of tools in my 40. Got the tyre changed an offered to sell them my spare 31"s if the cut in the sidewall wasnt repairable :lol: Will wait an see if I hear from them :lol:
Didn't barbie drive a jeep??
mike
Last minute Mike
Re: 20th/21st March
Post by mike »
Painted surf bars black thursday night with the help of suzuki1k, finished them last night + did the wheels. Put it all back together this morning, winch in,wired, all painted and ready to go.
Will put the new flares on tomorrow.
cleaned the garage out and tacked the seats in place in the LR. Very comfortable but way less visibility than it used to have :? at least turoa will be happy :wink:
will finish the shock mounts and get the shocks all bolted in after the flares on the surf in the morning.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
Andrew1706
Re: 20th/21st March
Post by Andrew1706 »
Bottom of my clutch master cylinder sprung a leak so no changing gears for the cruiser :cry:
wopass
Re: 20th/21st March
Post by wopass »
was 80 series maintenance day today
timing belt
big end bearings
fuel filter
oil filter
oil
engine bay clean
tomorrow mow lawns then see if i have tome to do the centre diff spool...
then back onto working on the missile :roll:
Heath
Re: 20th/21st March
Post by Heath »
Wired in the digital gauges - they are SWEEEEEEET :D
Noeyedeer
Re: 20th/21st March
Post by Noeyedeer »
Im in the process of cleaning up the 45 so I can get it re vinned.Started work at 5 this morning but good fortune had me finished by 9,so back home to the man cave and in to it.Fuel tank had a slight leak, took that out fixed that,took the flat deck off cleaned everything up from the cab back and painted it black.Got some white spokes a while back and had em sand blasted and painted picked those up yesterday,had planned on getting the 33s put on the rims this morning but ran out of time and money :lol: will carry on again tomorrow hopefully :D
94 Pajero 2.8 TD
76 FJ45 Cruiser
possum70
It was a Ford Hilux I think?
Re: 20th/21st March
Post by possum70 »
Drinking Homebrew :twisted:
Rattley old Hilux !!!!
V8 Cruisers Rule!!!!
mudslut
Re: 20th/21st March
Post by mudslut »
Done a bit of work on the samurai this weekend finally.Replaced rear wheel bearings,rebuilt swivel hubs,fitted some new coils in the rear and finished off the body lift
92 safari 17
Re: 20th/21st March
Post by 92 safari 17 »
Went to Woodhill, had a breat day :D , tracks are abit too dry tho
Furgus
Re: 20th/21st March
Post by Furgus »
Well not exactly 4 wheeling....but I used the 4wd tractor to drag logs up a rather steep bank so that they could be chopped for firewood. I used the 130 as a pivot point with a pulley block & a 30m winch wire rope. Worked a treat but I'm knackered........
mike
Last minute Mike
Re: 20th/21st March
Post by mike »
bugger if the 110 disappeared over the side :cry:
chopped the sliders on the surf to fit the rear flares. finished all the shock mounts on the LR, gus cutting, griding and welding all day. bit of fun :mrgreen:
1994 Toyota Surf
DieselBoy
Re: 20th/21st March
Post by DieselBoy »
Squeezed some gear in the Zook and went bush for the weekend.
Went bush crashing with a GPS and very old map and found some cool stuff. Also didn't find some stuff but spent a full day bush crashing looking for it :lol: :lol: Rematch with better info :mrgreen:
Ever feel like your being watched??
If you do recognise where we went, shut up and keep it to your self, its a public forum, absolutely anybody could be reading this :wink: :wink: :wink: :wink: :wink:
mike
Last minute Mike
Re: 20th/21st March
Post by mike »
up skippers somewhere right :?
1994 Toyota Surf
Toymota2
Re: 20th/21st March
Post by Toymota2 »
Change the rear diff, transfer box, gearbox and front diff oils today in the Paj and removed the towbar ready to fit my new tow hook mount. Also had a fiddle with the Evo and went for a little tiki tour.
Mitsi ZR4 E39a
83 Nissan Laurel
SWB V6 Pajero
wopass
Re: 20th/21st March
Post by wopass »
nah its over raglan somewhere... bridle veil falls?
mroffroader
Re: 20th/21st March
Post by mroffroader »
Jealous of your suzuki weekend pete and chris.....bastards :lol:
Taz
Re: 20th/21st March
Post by Taz »
The Land Rover decided it didn't like having some of its electrics fixed, so it broke something else. Tried to close it up a bit with the jack but its hardly problem solved :lol:
Stage1V8
Re: 20th/21st March
Post by Stage1V8 »
mike wrote:bugger if the 110 disappeared over the side :cry:
130 not 110 ;)
More length and weight.
Looks like it would have been fun but.
Alan
Land Rover Series III Stage 1 V8
Disco 2 HSE
wopass
Re: 20th/21st March
Post by wopass »
Taz wrote:The Land Rover decided it didn't like having some of its electrics fixed, so it broke something else. Tried to close it up a bit with the jack but its hardly problem solved :lol:
doood thats awesum!! just weld it back up and way you go :mrgreen:
TJared
Re: 20th/21st March
Post by TJared »
I shot over to brisvegas with a mate
Went to the national 4 x 4 show
Lotsa new ideas and more stuff to spend money on
* sigh*
actually didnt buy anything on the spot
nuts
Location: somewhere arround westcoast offroading usually
Re: 20th/21st March
Post by nuts »
wel i got hillfillys terano in me carport doin mods for easter so fsar snorkle fitted bigger tires pannelbeated front drivers side where i baked into it a couple of yrs ago ...ooops now doing bullbars at the moment and rock sliders if i get time with the jelp of a couple of freinds :)
Re: 20th/21st March
has your welding inproved nuts :D
nuts
Re: 20th/21st March
Post by nuts »
hell no i use super glue now :P :P :P :P
hillfilly
Driving Ms Daisy
Re: 20th/21st March
Post by hillfilly »
nuts wrote:wel i got hillfillys terano in me carport doin mods for easter so fsar snorkle fitted bigger tires pannelbeated front drivers side where i baked into it a couple of yrs ago ...ooops now doing bullbars at the moment and rock sliders if i get time with the jelp of a couple of freinds :)
http://www.offroadexpress.co.nz/Forums/ ... 18&t=20560
He is supposed to be resting ..... :roll: :roll: :roll:
Typical man never listens :wink: :wink: :lol: :lol:
but you couldn't have a better friend when you can't weld and a blonde mechanically :oops: :oops: :lol: :lol:
Not what if, but why not
