Crank pressure test?
DaveM
Post by DaveM »
Anyone know what crank pressure tests show?
Mate had an AA check done on a 3.0td Surf and had the following results.
CP Idle 30-40 L/min
CP Idle 50-60 L/min
Just unsure if these are good.
Dave
wopass
Re: Crank pressure test?
Post by wopass »
crank pressure test?? :?
vvega
Post by vvega »
interesting test ....
pressure in normally measured in psi or kpa .. becaue this is a measurement of pressure
l/min is normally a measure of flow
can you clarify :d
Kiwi4x4
DaveM
Re: Crankcase pressure test?
Post by DaveM »
Will ask him again today, but I've never heard of this before :?
smurf182
Post by smurf182 »
Sounds to me like a measurement of how much gas is getting past the rings into the crankcase.
SMOKEY
Post by SMOKEY »
This to me sounds like an engine blow by test, when Komat'su and CAT are doing there tests on our Loaders they have a gauge they fit to the crankcase breather that measures blow by, I haven't seen the result sheet to see how it is measured but Lt/Min would sound right. I know that even on new engines the figures are quite high.
FITZY.
DaveM
Post by DaveM »
Yeah, can only think of measuring blowby, just not sure what is a "good" result is
vvega
Post by vvega »
How Much Blowby Is Normal for an Engine?
How much blowby is normal? Dividing an engine�s maximum horsepower output by 50 will give you a ballpark number for how much blowby you would normally expect to see. For example, a street performance engine that makes around 500 horsepower will typically have about 10 cfm of blowby with conventional pistons rings and ring end gap tolerances. Higher performance engines that are built to tighter tolerances will usually have less blowby, as might those with gapless piston rings. An 800 to 900 horsepower NASCAR motor, for example, might only have 5 cfm of blowby.
Less blowby means more usable horsepower. Being able to baseline the actual blowby in an engine means you can then go back and try different ring configurations, ring types (conventional or gapless), different ring end gap settings and cylinder wall finishes to see which combination gives the best seal and the least amount of blowby.
Measuring blowby has been one of the best kept secrets with performance engine builders because it allows them to see how well the rings are or are not sealing. It also allows them to detect any ring flutter that may be occurring within a particular rpm range, and to then change the mass or end gaps of the rings to minimize the problem.
Kiwi4x4
lilpigzuk
Tiger Balm
Post by lilpigzuk »
vvega wrote:How Much Blowby Is Normal for an Engine?
you missed the rest of the article vvega
http://www.aa1car.com/library/engine_blowby.htm
vvega
Post by vvega »
meh took 5 seconds to find on google ... there must be better ones out there more suited to diesal's
personally i dont see the point of the test seams kinda stupid
Kiwi4x4
darinz
Post by darinz »
And from observation, deisel have ALOT more blowby.
haynzy
Post by haynzy »
darinz wrote:And from observation, deisel have ALOT more blowby.
Higher compression :wink:
DaveM
Post by DaveM »
I agree with vvega, I can't see the point in having this done, especially on a Pre Purchase Inspection, surely Compression and Leak Down are more relevant?
