Diff gasket leaks
mudmike
Diff gasket leaks
Post by mudmike »
Been having lots of issues with rear diff gasket failing. normally after a hardcore trip, get little puddle on driveway. when I pull it out find the bottom section has been blown out. also find that nuts are a bit loose.
Would this be from taking hits on diff head?
I'm using terrain tammer gaskets that seem thin but not had issues with any of the others.
The diff is a factory e-locker, in a Kzj78.
always use non setting jointing compound when putting togeather.
Is it normal to go through these, also any ideas on how to slow or stop it happening.
thanks for any help.
gimmemud
Re: Diff gasket leaks
Post by gimmemud »
I just use LOTS of red goo. haven't had a seal fail yet
sj408
Post by sj408 »
Yeah What he said :D just make sure the surfaces are clean & don't have any burrs on them.
kbushnz
Post by kbushnz »
Hi Yah
I use Loctite Master Gasket...
And no gasket..
Never leaked...
And although it sets hardish, comes apart easily.
As with all sealants / gasket compounds both surfaces need to be very clean.
I have same setup but a Retro fitted Elocker in KZJ78...
You have to ask the question is a location pin loose / missing?
Are the faces flat.
Is the breather blocked and pressurising the diff.
Have fun...
Calvin
UBZ
Post by UBZ »
I was having the same drama , finally figured out that i was filling the diff with oil to fast after reassembly and not allowing the gasket sealer to cure properly first.
Using locktite flexible gasket sealer and no gasket at all, no leaks since.
mudmike
Post by mudmike »
Thanks for all the feed back, didn't think of checking if the breather was blocked. Will pull apart again and use straight goo let it set well and hope.
thanks
pradon35s
Post by pradon35s »
hey man.. thats crazy cos i got the kzj78 too with factory e locker and i noticed mine leaking last w.e and jumped underneath to have a look and yea about 4 bolts at the 6-9 oclock position were like not even finger tight tripped me out.. but first time ive struck it and had truck bout 7 months
Andrew1706
Post by Andrew1706 »
When I rebuilt the front diff in my 80 series there was a number of bolts that were barely finger tight on it as well.
I've since had both diffheads out and sealed with gasket goo and haven't had any problems.
axel
Post by axel »
Hey, I've got the same problem with the rear diff gasket on my kzj78. When you replaced the gasket did you have to take the axles out to get housing off?? This would include wheels and everything right?
kbushnz
Post by kbushnz »
To get the diff head out, you need to remove the axles...
Calvin
axel
Post by axel »
Thanks. What if I just want to do the diff gasket, the diff head can stay in right? so do I still need to take the axles out to get at the gasket?
Pedro
Post by Pedro »
axel wrote:Thanks. What if I just want to do the diff gasket, the diff head can stay in right? so do I still need to take the axles out to get at the gasket?
yup
axel
Post by axel »
Cheers. Well that might have to wait till I cough up for a locker.
Pedro
Post by Pedro »
axel wrote:Cheers. Well that might have to wait till I cough up for a locker.
a option and i am not sure if this will work, is to unbolt the diff head and see if you can move it forward 4-5mm, if you can, degrease the hell out of the flange, inject rtv into gap and retighten the bolts, could be quick fix , like i say it may not work
cheers pedro
Return to “Toyota”
