20th/21st March
20th/21st March
Just swaped my 3 inch lifted coils for 4 inch and my 33s for a set of 35s
Noticed when i picked the truck up with the fork lift the brake pipes are tight so will have to put some longer ones on
Re: 20th/21st March
worzel wrote:Just swaped my 3 inch lifted coils for 4 inch and my 33s for a set of 35s
Pics please
Re: 20th/21st March
Will try and get pic for you Trev in the week
Re: 20th/21st March
well only jut got my trailer finished
after getting it off motorhead afew months ago
just gotta put sum paint on it then its all ready to carry this
and the trailer
and the trailer
its not how big the 4x4 is its how angry the diver is
Re: 20th/21st March
Headed round to red rocks for the first time last night cos I finished work at 4pm (early for me). Pretty nice night for a drive. Had a bit of a play on the little hill climbs then found a couple of guys in a standard terrano with a flat tyre no tools an a padlocked spare
Luckily for them I had plenty of tools in my 40. Got the tyre changed an offered to sell them my spare 31"s if the cut in the sidewall wasnt repairable
Will wait an see if I hear from them
Didn't barbie drive a jeep??
- mike
- Last minute Mike
Re: 20th/21st March
Painted surf bars black thursday night with the help of suzuki1k, finished them last night + did the wheels. Put it all back together this morning, winch in,wired, all painted and ready to go.
Will put the new flares on tomorrow.
cleaned the garage out and tacked the seats in place in the LR. Very comfortable but way less visibility than it used to have
at least turoa will be happy
will finish the shock mounts and get the shocks all bolted in after the flares on the surf in the morning.
1973 SWB Land Rover V8 Hybrid
1994 Toyota Surf
1994 Toyota Surf
- Andrew1706
Re: 20th/21st March
Bottom of my clutch master cylinder sprung a leak so no changing gears for the cruiser
Re: 20th/21st March
was 80 series maintenance day today
timing belt
big end bearings
fuel filter
oil filter
oil
engine bay clean
tomorrow mow lawns then see if i have tome to do the centre diff spool...
then back onto working on the missile
timing belt
big end bearings
fuel filter
oil filter
oil
engine bay clean
Re: 20th/21st March
Wired in the digital gauges - they are SWEEEEEEET
Re: 20th/21st March
Im in the process of cleaning up the 45 so I can get it re vinned.Started work at 5 this morning but good fortune had me finished by 9,so back home to the man cave and in to it.Fuel tank had a slight leak, took that out fixed that,took the flat deck off cleaned everything up from the cab back and painted it black.Got some white spokes a while back and had em sand blasted and painted picked those up yesterday,had planned on getting the 33s put on the rims this morning but ran out of time and money
will carry on again tomorrow hopefully
94 Pajero 2.8 TD
76 FJ45 Cruiser
76 FJ45 Cruiser
- possum70
- It was a Ford Hilux I think?
Re: 20th/21st March
Drinking Homebrew
Rattley old Hilux !!!!
V8 Cruisers Rule!!!!
Re: 20th/21st March
Done a bit of work on the samurai this weekend finally.Replaced rear wheel bearings,rebuilt swivel hubs,fitted some new coils in the rear and finished off the body lift
- 92 safari 17
Re: 20th/21st March
Went to Woodhill, had a breat day
, tracks are abit too dry tho
Re: 20th/21st March
Well not exactly 4 wheeling....but I used the 4wd tractor to drag logs up a rather steep bank so that they could be chopped for firewood. I used the 130 as a pivot point with a pulley block & a 30m winch wire rope. Worked a treat but I'm knackered........
- mike
- Last minute Mike
Re: 20th/21st March
bugger if the 110 disappeared over the side
chopped the sliders on the surf to fit the rear flares. finished all the shock mounts on the LR, gus cutting, griding and welding all day. bit of fun
1994 Toyota Surf
1994 Toyota Surf
Re: 20th/21st March
Squeezed some gear in the Zook and went bush for the weekend.
Went bush crashing with a GPS and very old map and found some cool stuff. Also didn't find some stuff but spent a full day bush crashing looking for it
Rematch with better info
Ever feel like your being watched??
If you do recognise where we went, shut up and keep it to your self, its a public forum, absolutely anybody could be reading this
- mike
- Last minute Mike
Re: 20th/21st March
up skippers somewhere right
1994 Toyota Surf
1994 Toyota Surf
Re: 20th/21st March
Change the rear diff, transfer box, gearbox and front diff oils today in the Paj and removed the towbar ready to fit my new tow hook mount. Also had a fiddle with the Evo and went for a little tiki tour.
Mitsi ZR4 E39a
83 Nissan Laurel
SWB V6 Pajero
83 Nissan Laurel
SWB V6 Pajero
Re: 20th/21st March
mike wrote:If you do recognise where we went, shut up and keep it to your self, its a public forum, absolutely anybody could be reading this
nah its over raglan somewhere... bridle veil falls?
- mroffroader
Re: 20th/21st March
Jealous of your suzuki weekend pete and chris.....bastards
80 series tow bus towing a redneck ass vitara
Re: 20th/21st March
The Land Rover decided it didn't like having some of its electrics fixed, so it broke something else. Tried to close it up a bit with the jack but its hardly problem solved
Re: 20th/21st March
mike wrote:bugger if the 110 disappeared over the side![]()
130 not 110
More length and weight.
Looks like it would have been fun but.
Alan
Land Rover Series III Stage 1 V8
Disco 2 HSE
Disco 2 HSE
Re: 20th/21st March
Taz wrote:The Land Rover decided it didn't like having some of its electrics fixed, so it broke something else. Tried to close it up a bit with the jack but its hardly problem solved
doood thats awesum!! just weld it back up and way you go
Re: 20th/21st March
I shot over to brisvegas with a mate
Went to the national 4 x 4 show
Lotsa new ideas and more stuff to spend money on
* sigh*
actually didnt buy anything on the spot
* sigh*
nuts
- Location: somewhere arround westcoast offroading usually
Re: 20th/21st March
wel i got hillfillys terano in me carport doin mods for easter so fsar snorkle fitted bigger tires pannelbeated front drivers side where i baked into it a couple of yrs ago ...ooops now doing bullbars at the moment and rock sliders if i get time with the jelp of a couple of freinds
Re: 20th/21st March
has your welding inproved nuts
nuts
Re: 20th/21st March
hell no i use super glue now
Re: 20th/21st March
nuts wrote:wel i got hillfillys terano in me carport doin mods for easter so fsar snorkle fitted bigger tires pannelbeated front drivers side where i baked into it a couple of yrs ago ...ooops now doing bullbars at the moment and rock sliders if i get time with the jelp of a couple of freinds
http://www.offroadexpress.co.nz/Forums/ ... 18&t=20560
He is supposed to be resting .....
Typical man never listens
but you couldn't have a better friend when you can't weld and a blonde mechanically
Not what if, but why not
