KZN185 surf
mudlva
KZN185 surf
Post by mudlva »
hi all had the timing belt replaced 10k ago and the clock has just ticked over the 200k and the little timing light has just come on
how do i switch the ligth off??
apart from using a little bit of tape over the light position on the dash :lol: :lol:
1rugger
Re: KZN185 surf
Post by 1rugger »
the earlier hilux's have a button which can be accessed on the cluster by pulling a small rubber bung out which is about the same location as the odometer reset but off to the left. if that makes any sense :roll: .
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
mudlva
Re: KZN185 surf
Post by mudlva »
cheers I justed looked and unfortunately there is no little bung thingy on the dash at all :(
keen for other susgestions tho :D
mudbugga
Re: KZN185 surf
Post by mudbugga »
If its not a digital dash, you'll need to pull dash gauge cluster out and swap screw over to reset the light.
gimmemud
Re: KZN185 surf
Post by gimmemud »
Pull the bulb out?
mudlva
Re: KZN185 surf
Post by mudlva »
gimmemud wrote:Pull the bulb out?
:lol: that just might be what happens if the dash has to come out and it start looking too hard :wink:
mudbugga
Re: KZN185 surf
Post by mudbugga »
Its a 10min job.
And to pull the bulb you'll have to take out the cluster anyway.
mudlva
Re: KZN185 surf
Post by mudlva »
mudbugga wrote:If its not a digital dash, you'll need to pull dash gauge cluster out and swap screw over to reset the light.
sweet then thanks for that info
will up date done
cheers :D
Return to “Toyota”
