nz new vs import 94 kzn130 surf.
1rugger
Post by 1rugger »
does anyone on here know the difference between the nz new and import surf?
as i think i'm going to need a new clutch soon and no longer have the details of the truck i wrecked to get the engine& box so carjam can't help me. as one has a dual mass flywheel and one has a solid flywheel & different clutches.
89 LN106 Hilux 3.0L turbo,2" bodylift 50mm suspension lift, lockrite rear, lsd front & 33" wranglers & winch
NJV6
Re: nz new vs import 94 kzn130 surf.
Post by NJV6 »
NZ new 4Runners never came with the 1KZ, the 1st 1KZ's to be sold new in NZ were the 90 series Prado's in '96.
NZ new Diesel ones were 2.8 3L's.
UBZ
Post by UBZ »
NZ new would be called a 4runner and import a Surf.
As far as know all import Surfs had the Dual mass flywheel , but is a common conversion to fit a solid flywheel.
When my dual mass gave up the ghost it felt like the clutch had gone , clutch was sweet but the dual mass was leaking fluid so stuffed.
do you know if you have a dual mas or solid? most good clutch places should be able to do either.
1rugger
Post by 1rugger »
dunno what mine is, that is what i'm trying to work out so i can get the clutch before i pull it apart, I'm guessing it's dualmass. & definitely clutch on way out as it was slipping when trying to spin tyres up in the mud :oops: .
UBZ
Post by UBZ »
if you can afford it , get rid of the dual mass and fit a solid, will only be a mater of time before the dual mass gives you dramas
mudbugga
Post by mudbugga »
Biggest difference with a jappa and a NZ new is the cooling systems are larger in the NZ and the chassis has extra braces for towing on the NZ. Is the same for the Prados.
Just something I was told by TNZ.
haydgq
Post by haydgq »
mudbugga wrote:Biggest difference with a jappa and a NZ new is the cooling systems are larger in the NZ and the chassis has extra braces for towing on the NZ. Is the same for the Prados.
Out of all the 1KZ's its the import Prado's and surf's with the Intercooled version of the 1kzte that dont suffer from the head cracking issue as they had the larger radiator's etc
1rugger
Post by 1rugger »
went out and had a look up the drain slot and it looks like a solid cast fly wheel when compared to this pic
Image and the engine & box have 350,000km's so gessing that some one would have replaced it already. can anyone confirm that the fwd face of the dual mass looks like this?
Lynx
Post by Lynx »
nope it doesnt look like that, its missing the actuall clutch face.
Cheers Daniel
1rugger
Post by 1rugger »
Lynx wrote:nope it doesnt look like that, its missing the actuall clutch face.
Cheers Daniel
correct me if I'm wrong but the clutch face would be on the other side(aft side of fly wheel) pic is of fwd side(engine side of fly wheel). which i can see from crank shaft to ring gear on fwd face and look's like a solid flywheel but not sure what the dual mass one look's like :?:
Lynx
Post by Lynx »
nope, thats missing the bit that your clutch actually sits on
1rugger
Post by 1rugger »
bugger, Thanks for the info Lynx, does anyone know if you can tell the difference between the two flywheel's when installed or give me a pic of the crank shaft side of the flywheel?
Lynx
Post by Lynx »
crankshaft side is just a solid plate. maybe 2mm thick, rivited to the back of the flywheel. theres oblong slots in it where the springs are, if you look at that pic you can see the pallet through one of the springs
Cheers Daniel
1rugger
Post by 1rugger »
i can see probably 1/4 of mine from the crankshaft side and it's one peice with no holes or rivits so i'm gessing i have a solid flywheel.
Thanks for you're help :D
Lynx
Post by Lynx »
No problem man, just been through all this drama with mine.
Cheers Daniel
mudbugga
Post by mudbugga »
haydgq wrote:Out of all the 1KZ's its the import Prado's and surf's with the Intercooled version of the 1kzte that dont suffer from the head cracking issue as they had the larger radiator's etc
Actually they had a different generation head as well.
And yes, they still crack heads :wink:
tweake
Post by tweake »
interesting to hear that.
otherwise imports are the same. don't forget 4runners are still a surf. just an upspec trim on the budget model surf.
Return to “Toyota”
