Terrano filly
Re: Terrano filly
Some of Possums all purpose home-brew should sort him out
nuts
- Location: somewhere arround westcoast offroading usually
Re: Terrano filly
bev is just loading the latest pics except 4 my hand
Re: Terrano filly
Looking good Hillfilly
But come on!!!! do I need to find the photos that show Nuts, bullbars and welding are a bad idea???
Scarfies on the piss,
Re: Terrano filly
I am beginning to think nuts and working on my truck are a lethal combination........
only for nuts
only for nuts
Re: Terrano filly
Closer view of indicator bracketis
Bolt through gusset into original bumper mounting bracket
View other end
View from bracket side through to gusset
Triangular piece of plate tacked in place
Rated towhooks in place
That's it for tonight..
The rest will come out in the wash
View other end
Not what if, but why not
nuts
Re: Terrano filly
hey y is the water red wen the towel is blue
Re: Terrano filly
nuts wrote:hey y is the water red wen the towel is blue![]()
Well we know you aint got Blue blood.. LOL
nuts
Re: Terrano filly
wel me hand is out of use for a bit so hav 2 get someone else to finnish welding up the bumper hopefully still get it finnished b4 the weekend
Re: Terrano filly
lucky you still have the hand to use nuts, cutting disc by name and nature, lots of stories out the about them
nuts
Re: Terrano filly
coxsy wrote:lucky you still have the hand to use nuts, cutting disc by name and nature, lots of stories out the about them
yeah im on intravenus antibiotics now as its infected
but still trucking just cant stop me
Re: Terrano filly
Cover plate bracket
External view tapered corner
External
Painted and final bolt going in
External
nuts
Re: Terrano filly
now easter is over guna make a run at the bar work again in a couple of days found the factory bumper mouting brackets are slotted so just slid out under load
so the plan is to weld up the slots and make new bolt holes and go for bigger bolts
Re: Terrano filly
good plan, suppose no room to put the recovery hooks straight on to the chassis
nuts
Re: Terrano filly
coxsy wrote:good plan, suppose no room to put the recovery hooks straight on to the chassis
na no room need to get it rite so we can put a winch inb and giv it a test
Re: Terrano filly
Very pleased with the way the new bar work protected my wee truck
Genious design or nuts is just used to my driving
Looks like it took a few
major hits and scrapes
but nothing that was too drastic
Still to get all the flora from out of the wee nooks and crannies for a proper look see at a few things that moved or bent a wee bit
Re: Terrano filly
I try
then I try harder .....
and when I'm totally stuck or about to do major damage I get told stop
I will have to make sure I remember my camera if I ever get up there and you're ever in the driver's seat Jerry
nuts
Re: Terrano filly
well easter over and ive done some more work on the bullbars xtra gussets to help take the strain away from the top of the bars mounted a gew9000 lb winch and built a nudge bar on top of the bullbar ,,, will upload pics asap
just got to get a winch rope for it and then do the side bar work to attach the bullbars to the side of the chasis where the rock sliders will be mounted as well
Re: Terrano filly
Bloody hell Nuts, that truck is changing faster than the coast bush!
Ph 0212078472
Ph 0212078472
nuts
Re: Terrano filly
nuts
Re: Terrano filly
kiwipete wrote:Bloody hell Nuts, that truck is changing faster than the coast bush!
cant get the individual pics to upload as the website sez they too big so have to use the link
Re: Terrano filly
Faster than I can keep up with it
nuts
Re: Terrano filly
http://s299.photobucket.com/albums/mm31 ... =slideshow
last of mod pics till i do some more added to this album
