9th - 12th April
9th - 12th April
Started to make up some storage in the back of the bighorn so dirty theives can't see what I don't have in the back, time to go cut down a tree in the back yard (hope it falls the right way)
Re: 9th - 12th April
got a permit to cut it down
Finished cleaning the truck after a few trips...
Wife happy to get it off the front lawn.
Then once dry, park it up and pull out the factory dump pipe and make a bigger one...
Calvin
Calvin
- 92 safari 17
saturday: Painted secound set of rims black and mounted a recovery hook to the back of my patrol,
sunday: goin to a 4x4 tag along
cut the tree down with no damage to property of myself. No permit needed in this case.
removed the hi volume ARB pump. fitted small diff locker pump instead
- geckoadventure
Hi im back - managed to get ourselves on TV From Malaysia you can check
http://www.4x4earth.com.au/watch-4wdtv/?e=216
It starts with us beating the crap out of a Honda in a carpark
Tomorrow im back in the water after about 6 months of no riverboarding.
- MNC
coxsy wrote:removed the hi volume ARB pump. fitted small diff locker pump instead
WHY?
the hi volume is a 12 volt 23 amp, to much draw from one battery, james can use it his 40 instead
pump in
switches in place, got to have a main power switch
new site for the 40s battery
pump in
As I said earlier, pull out factory dump pipe. Yeah right...!!!
Removed front pipe ok... Few bolts seized, bit of biffo and they came loose.
Three bolts on the flange all stuck fast and corroded away.
Split those nuts
Now for the dump pipe on the turbo..
Had it all apart about 5 years ago... Bit tight but do-able.
Got them all bar one
And the nut is stuffed...All corroded away.
So its Exhasut manifold off and turbo out.
More stuck nuts....
Finally finished..
Now I can get back to what I was wanting to do.
Calvin
Split those nuts
More stuck nuts....
Finally finished..
Calvin
when you put it back together cooper coat the nut and threads
went to Whitianga Festival of speed for the weekend. was awesum.
Copper coat...
Yeah I did that last time..Heaps of it....
Works good on cold bolts.
But I think it gets too hot for copper coat so have some new stuff.. Nickel based.. Worked fine on the pyro fitting.
See what happens..
Calvin
See what happens..
Calvin
Another great day at Woodhill on Patrol. Cooked winch control pack....gives me something to do in the week.
http://www.youtube.com/watch?v=vSWb890b5x4
http://www.youtube.com/watch?v=TnblYwzvisU
you found mud up there
worked on truck, got a bit done, and finished making a mould for VN GP A Commodore centre console to fit a BM shifter
coxsy wrote:you found mud up there
yeah, not much. Everyone else has got the good footage of today.
Will post on my U tube account as soon as I get hold of it.
P.S. I welcome all subscribers.
what happened to the last 4wd on the last video? did it not make it up?
snork wrote:what happened to the last 4wd on the last video? did it not make it up?
Ah.....no. Will post what happened to it next.
sibainmud wrote:snork wrote:what happened to the last 4wd on the last video? did it not make it up?
http://www.youtube.com/watch?v=VVo9PXlSMiM
