Emu 2 inch suspension lift.
- Driver/Navigator
Hey guys,
Im looking at getting an emu 2inch suspension lift..Correct me if im wrong but this will give me more clearance? Ive been qouted $1700 + Gst.Is that about right? Or how difficult is it to do yourself? Cheers.
- Driver/Navigator
Re: Emu 2 inch suspension lift.
That is for a 91 Surf..
So that would be just for two rear springs and four shocks with the torsion bars wound up?
Sounds bloody expensive to me.
- Driver/Navigator
not sure what makes up a suspension lift kit mate to be honest.I made an enquiry with a 4wd specialist mechanic in Wellington thats the price I got?
- Sadam_Husain
- Angry bird
it would give you more clearance between the tyres and guards for articulation but it wouldnt give you any more ground clearance so you'll still get hooked up on the same stuff that you already get hooked up on
- Driver/Navigator
Sadam_Husain wrote:it would give you more clearance between the tyres and guards for articulation but it wouldnt give you any more ground clearance so you'll still get hooked up on the same stuff that you already get hooked up on
Wow, I emailed a 4wd mechanic and said I was catching my tail pipe when coming back over devils gate,he said a emu 2 inch suspension lift would sort that out.Hmmm now Im confused.So how do I get more ground clearance? Suspension lift + taller tyres?
Your suspension lift would lift the tail pipe and the rest of the chassis but your diffs would remain as lowest point. Only tyres will lift those up. There are probably a lot cheaper ways to suspension lift a surf too. Check Maxitrac at Repco.
85 Hilux single cab
02 Grand Vitara
02 Grand Vitara
- Driver/Navigator
Ok cheers mate that makes more sense to me now..Ill do a bit of research.
or just reposition tailpipe of thats your only prob
- muddyhilux
i fitted 2" kit to my 90 surf,been in there almost 5 years and drives like a dream,really good handling etc and considering its on 35s etc it should have alot more sway then it does so yeh,id do it again
kit for the price should include 2x rear springs 2x new hd torsion bars 4x shocks and a new steering damper
i installed y kit with a feew mates,all was easy and would have been done n a day but took 2 due to a broken torsion adjustment bolt
trick for these is soak with crc the day before,then make sure no weight is on the front end when you undo them,take it slowly,undo a bit then re tighten,undo some more then retighten etc untill its out
- Driver/Navigator
muddyhilux wrote:i fitted 2" kit to my 90 surf,been in there almost 5 years and drives like a dream,really good handling etc and considering its on 35s etc it should have alot more sway then it does so yeh,id do it again
wicked! Which kit did you go for? I might do a backyard mechanic jobbie too.I have a mate who is pretty handy with cars.Thanks for all the info its a big help.
yeah that price sounds like a complete kit including Torsions and a steering damper
remember- QUAILITY IS LONG REMEBERED LONG AFTER THE PRICE IS FORGOTTEN!!
I have a 1990 surf, i have had a 45mm body lift and im running 33 inch tyres. tyres cost me $300 second hand, body lift about $500 installed from memory.... if you want any more info PM me..
- muddyhilux
bruntonjm wrote:I have a 1990 surf, i have had a 45mm body lift and im running 33 inch tyres. tyres cost me $300 second hand, body lift about $500 installed from memory.... if you want any more info PM me..
yes but then add 500 to that for cert if you someone who abids by the law,also body lift will do nuthing to aid a crap ride due to old suspension,and
badnuz wrote:yeah that price sounds like a complete kit including Torsions and a steering damper
this is very correct,best money i spent
kit wise it was just 2" lifted rear springs,heavy duty torsions,i also chose the heavyer rated springs due to gear i carry all the time,and no worries,glad i could help,yeh back yard jobby is easy enuf,just reli need jack,spring compressors and basic hand tools,like i say just crc the crap outa those bolts,if you can get hold of a second set of bolts beforehand you completly remove the risk,it killed my job,i eas just luucky to get new set by the next day
- muddyhilux
500 is a bit steap,also ad cert to that and you should of had a steering shaft spacer madse and fitted or later model steering shaft fitted as just slipping the spline wont pass cert,nor is it very safe,especially if your upping wheel size
muddyhilux wrote: you should of had a steering shaft spacer madse and fitted or later model steering shaft fitted as just slipping the spline wont pass cert,nor is it very safe,especially if your upping wheel size
so where can you get a steering shaft space made up?
- muddyhilux
an engineer can make one up for you,pretty basic but vital to return steering to full strength
