Landyota wrote:Hi all, new member. Currently placing LJ78 Prado front and rear axles under a LandRover Discovery. Rear complete, begin front tomorrow. The LJ78 Beam front axle has 'power hubs', the concept leaves me cold. I have a spare set of Aisin maual hubs off a surf sitting here, would be good to use those, but could be issues from what I read. There was a guy called Old Blue or similar that used to post on here and TradeMe with a 'manual' conversion for the exisiting hubs, is he / they still around / available? Or does someone have some sharp idea that may point me in the right direction? Cheers Shane.
All you need to do is get a set of hilux stub axles and hubs as they bolt straight on to the Prado swivel housing and the 30spline FWH's you have bolt straight on. That way no modifications needed
