Wanted :: Hilux calipers for solid discs setup
Selling or wanted vehicles.
cooksworld
Post by cooksworld »
Hi - I trying to track down a pair of calipers from a solid disc braked hilux - these are the ones I need to replace:
Post: http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=18&t=16582
Ideally in Wellington but keen to hear from anyone with some.
I've also heard that the ones marked 'S12-8' were used on 60 and 70 series fronts.
andrew007
Re: Wanted :: Hilux calipers for solid discs setup
Post by andrew007 »
why not get them stainless steel sleeved?a company down here does it.or give lineside a ring 0800444589.
cooksworld
Gave Lineside a call and they don't have any in stock and they rarely get them these days. Took the calipers into ABC in Wgtn and they said they could redo them but was going to cost around $400... eek! Will keep look for some good 2nd hand ones of look at bolt on spacers to offset the wheels I guess and use my 60 series parts...
meatc
Post by meatc »
I do have a set, but not sure if I want to part with them. They would need a seal kit and a bit of a clean up but they sere still working whe I pulled then off an axle a few weeks back.
PM me an offer and I will decide if I will let them go.
