To sway bar, or not to sway bar....
Muddboots
Post by Muddboots »
Just fitted some new Old Man Emu springs to my JB74, and noticed that the sway bar holds the axle up. I know a lot of people remove the sway bar for off-road use and was wondering is it worth doing or will it just handle like crap :?:
Any suggestions / comments would be appreciated as I'm still quite new to 4wding. Cheers
You Get That
Re: To sway bar, or not to sway bar....
Post by You Get That »
Might pay to check this out.............
http://www.offroadexpress.co.nz/Forums/viewtopic.php?f=13&t=4396&hilit=swaybar
It really varys between trucks tho.
The easy answer is to try it, Its easy enough to put back on if you dont like it. :mrgreen:
Addicted to suzukis....
vvilly
Post by vvilly »
i went in for cert on big girl long story got rejected, i had to get the steering and handling fabricated. new laws state that if you lift a truck it has to handle like a factory one a couple weeks later rick at 4wd accessories sorted it all out.now she turns on a dime and handles like a mr2 hahaha
so yes to sway bars you can always detach one side when you play as i do
jase
juz
Post by juz »
Just certed my Safari couple weeks ago, flew through both Cert and WOF with no sway bar.....And definatly doesnt handle like Factory. He also told me ya cant cert any lift higher than 100mm over standard now, thats body and spring combined.
Swamped
Post by Swamped »
So what happens to everyone else that's already cert'd over 100mm? The cert guy I deal with has never mentioned anything, he always says its at his discretion basically...
Anyways, check out the other thread, opinion varies from wof guy to wof guy and model to model so try it. My patrol has always passed without one from multiple places - Ebbett holden and vtnz to dodgy wof guys.
vvilly
Post by vvilly »
thats what sucks aye i suffer with inconsistancies at work all day long ya think with this sort of thing would be simple and no grey matter. to cost one man 3k and another sweet as bro lol well my truck got a larger than 100mm lift by far and that went through
rokhound
Post by rokhound »
I have been trying to keep in touch with my cert guy and he has never mentioned a max-over-standard height. I hope you are wrong because mine is 300mm of lift, but there is not one bit of standard suspension left and as far as I'm concerned it is at standard height now :P
Back on topic, If your rig is driving like a total pig (very common for lifted trucks) fit bigger sway bars with quick disconnects. Simple solution really.
vvilly
Post by vvilly »
done and suggested yes
tallsam66
Post by tallsam66 »
There are lots of stories going around about needing & not needing stuff & heights etc.
The only fact is there are no heights mentioned in any documentation about lift heights etc.
Its all down to the individual certifier & if he thinks its safe or not.
Return to “Toyota”
