Auto hub question
minefield
Auto hub question
Post by minefield »
I have just fitted auto hubs to my pajero, But I'm not sure if what I have done is right.
When I took off the manual hub cover, Removed the cir-clip but then there where 2 dome head screws that would not allow the auto hubs to be fitted, Not sure what the screws were holding but I removed them anyway so the auto hub would slide all the way on
Every thing appeared to be ok but it feels odd not puting the cir-clips back on.
What if anything have I done wrong??? :?
Nissan Safari SWB Auto ,50mm suspension Lift , 50mm body lift, 12000lbs winch,
33x12.5x15 Perilli scorpion muds
lincooln
Re: Auto hub question
Post by lincooln »
Do they work? as in have you tested them yet?
Lubrication Specialist
Lubrication Engineers
NJV6
Post by NJV6 »
Why would you replace manual hubs with dodgy auto hubs?
Pajmad
Post by Pajmad »
The auto hubs use a flathead countersunk screw in place of the dome head they hold your wheel bearing lock ring in place
1992 lwb Pajero 2.3tdi 15psi Keeping It Real
minefield
Post by minefield »
Pajmad wrote:The auto hubs use a flathead countersunk screw in place of the dome head they hold your wheel bearing lock ring in place
Thanks , I thought that was the case, I have only done a few k's so I'll get the countersunk screws before I go too far :)
Return to “Mitsubishi”
