im looking for a snorkel for my 87 nissan navara/datsun.....watever you wana call it!
now can you just pull one off a terrano and fit it on to the datsun or are they slightly different ???
im pretty sure the air intake is on the right hand side of the engine bay looking at the ute from the front????
its got dunlop super grippers on the rear but they arent very wide, was thinking of putting them on the front and getting some wider wranglers or maxis muddies for the rear???
any ideas???
Navara Snorkel
- Navara_Man
- Driver/Navigator
Navara Snorkel
If it doesnt work hit it, if it still doesnt work shoot it
Re: Navara Snorkel
I put a airtech one on mine,supplier was in hamilton can't rember their name and a small thing to watch for is the curve in the front guard there is a differance nearly caught me out it could be the differance between yours and terrano
Re: Navara Snorkel
Make one out of exhuast tube.
Re: Navara Snorkel
darinz wrote:Make one out of exhuast tube.
Or look up "autobend" here in Chch, they will bend one up out of their machine to the right speks for you.
Ph 0212078472
Ph 0212078472
- Navara_Man
- Driver/Navigator
Re: Navara Snorkel
Cool thanks just curious would alkathene do the trick say 40 or 50mm size wise???
Re: Navara Snorkel
Look at it this way, the longer the pipe, the bigger it needs to be to supply the same amount of fluid (air being a fluid). So what size is the inlet then increase that by about 15 to 20mm at least and you'll be OK.
