"ARB WINCH BAR"
tintin
"ARB WINCH BAR"
Post by tintin »
will fit KZN185 and VZN185 96 on surfs or 90 series prados,
air bag compatible, doe's not include winch
1980 4x4 Hilux Restoration Image
UBZ
Re: "ARB WINCH BAR 4 SALE"
Post by UBZ »
You buying yourself a new toy???
any pics? and is there a model no on the bar so I can see if it will fit my KZJ?
tintin
Post by tintin »
part number 3421052
tintin
Post by tintin »
part number 3421050
i still have the fitting instructions,
you could modify excisting mounting brackets or make new ones to fit anything (anything is posible)
4runner
Post by 4runner »
hi, do you still have it? where abouts are you?
tintin
Post by tintin »
i still have it , im in TeAroha
4runner wrote:hi, do you still have it? where abouts are you?
tintin
Post by tintin »
bump, still got it
Mattman
Post by Mattman »
How much are you looking for?
tintin
Post by tintin »
Mattman wrote:How much are you looking for?
they are just under $2000 new, has a few sratches, make an offer
flyingbrick
Post by flyingbrick »
That looks like it fits real nice- i like how close it sits to the guard and grill 8)
tintin
Post by tintin »
8)
tintin
Post by tintin »
sold
koma
Post by koma »
what size wheels and off set are you runnning on that surf? Cheers
tintin
Post by tintin »
koma wrote:what size wheels and off set are you runnning on that surf? Cheers
was running 265/75/16 , im unsure of offset of the rims cause i bought them 2nd hand
koma
Post by koma »
Cheers, did you need to lift it to run them or not? Those bars look sharp to, very tempting.Cheers
tintin
Post by tintin »
koma wrote:Cheers, did you need to lift it to run them or not? Those bars look sharp to, very tempting.Cheers
i had a 50mm suspension lift and a 25mm body lift and they still rubbed a little now and then
ashleygt
Re: "ARB WINCH BAR"
Post by ashleygt »
Just checking to confirm that this is the same bar as you had fitted to your surf? Cheers in advance. http://www.trademe.co.nz/Browse/Listing ... =289344136
badnuz
Re: "ARB WINCH BAR"
Post by badnuz »
Same bar :)
ashleygt
Re: "ARB WINCH BAR"
Post by ashleygt »
Cheers, was preatty sure. What are these things worth new?
badnuz
Re: "ARB WINCH BAR"
Post by badnuz »
more than 4 hundy!
koma
Re: "ARB WINCH BAR"
Post by koma »
Hey Im looking at doing a 25mm body lift, did you run into any troubles in the process? Cheers in advance.
