Hi Guys how are you all doing?
I am new to this forum and am looking for some help please.
I have not long had my Cruser like just under 1 week, when i went through i big puddle on the road and now it will not stop leaking from around the heater fan and it is clean water that is leaking also.
Thanks guys for taking the time
Phil
leaking 2001 landcruser
Re: leaking 2001 landcruser
Could be any number of things.
First thing that springs to mind is water washed over bonnet, into grill and is back draining into fan housing.
Take fan housing off and remove trapped water.
Otherwise......
If your Toyota is like mine, there is a big rubber grommet which the antenna wire goes thru. This could be dislodged from its hole.
It exits to the inner gaurd and if you went puddle jumping it could have splashed in.Also there is another one for the door wiring.
Or do you use your Aircond alot. It could be leaking inside the truck.
Check its drain line isn't blocked or dislodged.
I had a hard to find leak once. Thought it was comming from floor level, but it turned out the sun roof drains (one each side) which follow the door pillar down were blocked with debris.
And one also had a small hole in it half way up.
Have fun.....
Calvin
Otherwise......
Have fun.....
Calvin
My guess is the aircon drains are blocked. if you run it cold for a few minutes in the garage (or a dry bit of ground) does a puddle form under the wagon? If not the drain may be blocked.
If that isnt the case do you have a sunroof? If yes as Calvin said
the drains for the sun roof may be blocked so it is draining into the footwell.
Thanks guys for that
how i have got somewhere to start looking,my truck also dose not have a sunroof.
would you be able to tell me where the aircon drain pipe will be as i would not have any idea where it is and what i am looking for.
Thanks again guy for your input
Phil
Phil
- skid
- Tyre Man
My 80 series had issues with leaky sunroof
When its open look in the front corners and there will be 2 holes there somewhere
You need a long thin wire to poke down there a few times to unblock it a bit
Wire needs to be long coz the drains go along roof, down A pillar and further down from there
try that and see how ya go
SKID
SKID
A/C drain should be a little plastic pipe hanging about half way along and above the front left radius arm by the bottom of the engine
Hey guys all fixed thanks
This is what the problem was
Well it's like this, the other day i went though a big puddle on the GT South Road in Penrose out side work O-I New Zealand (The old ACI Glass) and didn't think anything of it,then the day after that i had seen water on the floor mat and said to my self thats odd.
So a long story short (thanks Calvin)i put down a ground sheet and had a look to see what i could see, and i lifted the inner lined and i had seen a little hose that was bent over.
Well....good old Phil do frist and think later. i pulled it out and all i and say is MOTHER F@$KER!! All in the face and up the nose and in the mouth.
well it's all fixed now and a big thanks to all the guys that helped me out and i hope that i can return it one day
Phil
Phil
Heheheeheheheh
Glad you found your leak.
And a free shower.
Calvin
And a free shower.
Calvin
