Hi can anyone give me some advice on setting the correct height on the front torsion bars on an old d21 terrano.
I am looking to wind up my bars and I was wondering how far I can do before I go over the original measurements. I was told you measure it from the top of the bump stops is this the case.
Any detailed advice would be gratefully recieved.
terrano torsion bar settings?
Re: terrano torsion bar settings?
[quote="kiwipete"]If you are winding up the torsion bars, leave a 25mm gap minimum at the upper bump stops so you still have some down travel. You will need to et a new wheel alignment ASAP as the castor settings will be all out of whack.
This works. Cheers
This works. Cheers
grytvikken
thanks mate
