My 70series cruiser
cruzerboy
My 70series cruiser
Post by cruzerboy »
Well it was pritty much standed when i got it apart from bullbar and snorkel
Then i put 50mm lifted springs and 50mm body lift and put 35s on it
then it went down hill from there put a winch and a rear lokka in it then did a shakel revesel so i could move the diff ford went up worslys and stacked it at 11oclook at nightlol the i thoght it would be a good idear too do a SOA and make it higher
then i farked around with the springs a bit too get it too flex a bit better and lower it a bit
then i put a set of 37s on it :twisted: :twisted: and tryed too roll it again
then i blew the lokka too bits so i decided too change evry thing again. Make it stronger and wider so im putting nissan safarifront diff with coils under it and 80series landcruiser diff with the leefs inthe rear and this is how it sits
this is how its been sitting for the last 2 months ill finsh it one day doesnt help that i bort another toy and been working on that :roll:
Bubba
Re: My 70series cruiser
Post by Bubba »
Wow, that looked nice when you got it!!
Now it looks, well ......better!!
Except for the front diff, that just wrong
Benjamin Franklin
lee22
Post by lee22 »
lovin your 70 mate looks really good now, big improvement :wink: :D
lee
MNC
Post by MNC »
cruzerboy wrote:then i blew the lokka too bits so i decided too change evry thing again. Make it stronger and wider so im putting nissan safarifront diff with coils under it and 80series landcruiser diff with the leefs inthe rear and this is how it sits...
Loving the flex from SOA etc... Any reason you decided Safari Diff with coils upfront and 80 Series with leaves in the rear?
badnuz
Post by badnuz »
the nissan diff has a lower profile???
cruzerboy
Post by cruzerboy »
I couldnt find a 80 diff for the front and i got the safari one cheap and it stronger than the toyota one.Im leven it leefs in the back cos it flexs good in the back so dont wana change what already works and im thinking of putting drop skackels in the rear.have 2 coil front cos the srings too close together and would be on top of diff head and i was having problems with the springs hitting the tierod so i decide coils will solve the problem
cruzerboy
Post by cruzerboy »
Lol Better then the other idear i had ive got anouther 70s body thats stright as was going 2 try and get safari that had a farked body and put the 70 body on it but i couldnt bring myself 2 do it
Bubba
Post by Bubba »
Thats one way to improve a nissian I guess lol
Do you find the diff covered in oil and crap, from when the rest of the Toyota parts spit on it?
Whats it like having a wider front than the back, do you even notice the difference. Does it make a difference on the trail with rutts etc. Are you planning on countering it with spacers in the rear?
Benjamin Franklin
cruzerboy
Post by cruzerboy »
lol yea i think its already rejecting the datsun parts cos the steering box has started leeking wasnt before it went in.Havent had it out those pic are how it sits at the mo in the pics it dosent have the new rear diff in it should be the same front and rear when the 80 diff is in the rear its about 20mm wider than the nisan one
basics
Post by basics »
dam i miss my 70 :cry:
looks awsome, safari diffs is all good in my books, width is a good thing if you going higher
keep the pics and info coming, :wink:
99 pajero exceed 3.2
zookfest
Post by zookfest »
Go the dirty 70 :twisted: loving that flex with soa with leefs :o
Death to the competition
cruzerboy
Post by cruzerboy »
Bit of a update been prity slack on working on it lol pics are prity shit took them on my phone
radius arms mounted
new panard bar mount
look melted nissan bits lol
cruzerboy
Post by cruzerboy »
spring mounts
sum bracing for the panhard bar
cruzerboy
Post by cruzerboy »
bit of a update
just got shocks to mount now then the front ends done.
I own a POS toyota with nissan bits in it.Basicly lives in the shed
H2OLOVA
Post by H2OLOVA »
about time you did a bit more :wink: Be all ready for a winter trip ya reckon??
cruzerboy
Post by cruzerboy »
yea hope so all the hard stuffs done now just got to mount the 80 diff in the rear and a few other bits and a couple of new lockers
cruzerboy
Post by cruzerboy »
since i havent been working for 2weeks now got a bit done to it got the 80series diff it the rear now and move it back 3inchs. put the wheels back on yesterday to see what it looks like.
just needs the rear gards choped shock mounts steering and brakes and a few other little things. also got a PTO winch for it now and scored a air ram from work so i can air freespoll it :D
basics
Post by basics »
after the chop thats gona look so good :D
cruzerboy
Post by cruzerboy »
did a gard chop yesterday :D
350cruiser
Post by 350cruiser »
you will enjoy the extra width with these diffs. my bj73 has 80 series diffs and suspension in it with 36'' simexs on it. great on the side of a hill. are you changing the brake booster and master cylinder from an 80 to match the rest of the brakes? if so get them from a pre 93 80 series as they bolt up with just a little loving to the brake lines to the master cylinder. unless the diffs are after 93(bigger brakes)
doesn't play well with small vehicles
cruzerboy
Post by cruzerboy »
yea should be good its 300mm wider than it was. haven got as far as the brakes yet but that sounds like itd be the go cheers
350cruiser
oh you will also need the 80 series brake pedal as well. with the pedal you will need to bend it towards the drivers seat(many many cuts down the spine and reweld) the 70 pedal doesnt fit as well from memory.
cruzerboy
Post by cruzerboy »
It moves under its own power now :D :D
got flex :twisted:
cruzerboy
Post by cruzerboy »
got sick of the leafs in the rear so ive coiled the rear now went with triangulated 4link with standed ln130 surf springs this is how it turned out
also got a ARB airlocker for the front and a tight lsd for the rear and 4.88 R&Ps
You Get That
Post by You Get That »
Man i love what you are doing good job :wink:
It looks nice with the coils now.
Addicted to suzukis....
basics
Post by basics »
this is still my favourite build up :D
cruzerboy
Post by cruzerboy »
changed the bumper a bit
cruzerboy
Post by cruzerboy »
started doing my ute chop
You Get That
Love this build ute chop starting to look sweet.
What motor has it got in it? Is it still standerd? 13B-T im gessing?
cruzerboy
Post by cruzerboy »
Yea just a 13bt with the pump tweked and some more boost
