As it arrived apart from the old 31s on the back for skids
An had to try doing a skid, bit too much grease on the pad but still good fun an sounded great
http://s851.photobucket.com/albums/ab74 ... f865c1.mp4
Had a bit of a look around it yesterday an decided it needs quite a bit done:
-engine gaskets replaced
-5 speed g/box fitted
-Chassis swap- its fatigued cracked an been butchered an a few places
-Body sand blastd an repaired (rust an damage)
-Roll cage, bar work an hillbilly light bar removed an redone when full fj45 roof is fitted
-The power steering needs to be completely done
-The engine needs to be moved forward about 50mm as it sits against the firewall
-Rear mounted radiator removed an one in engine bay plumbed up properly
-Front Brake lines replaced
-Full rewire maybe dash cut out an unmolested one welded back in
-Front an rear diffs will be replaced by larger coil sprung disc brake units
-Tube guards front for clearance an to cover the 36's
Will add to this list when I think of more sh#t it needs
