Can anyone help with winch wiring?
Big-AL
Post by Big-AL »
what do i need to do (in very non-technical terms) to wire up this winch?
Storm
Re: Can anyone help with winch wiring?
Post by Storm »
Hey Al, this may help as I see the solenoid box cables are still attached :)
http://www.youtube.com/watch?v=U8Y6zp0_ ... re=related
www.williams4x4.co.nz
Landy Rover
Post by Landy Rover »
Not sure if Chinese are all the same, but on mine the red goes to the one near the motor cap, yellow to the top one and black to lower one.
S3 Rover truck cab, injected 186, Sals rear,Toyota P/steer, Safari disc brakes front, R/Rover D/brakes rear, 9500 winch,twin optima batts, roll bar, Disco seats, 33" JTs, scene lamps, onboard air, Front ARB locker.
Big-AL
Post by Big-AL »
thanks got it sorted, you were right :)
Big-AL
Post by Big-AL »
the winch has been sitting for about 6 month, now one solenoid is sticking open, and the other is clicking. does anyone know if they are able to be pulled apart and cleaned? ... and how?
kbjj
Post by kbjj »
I have pulled solinoids with that type of crimped housing appart by machining the crimp off in a lathe. Maybe a hacksaw cut around peak off crimp would do same thing. But... you have to tack weld it back together. I think Christchurch Auto Electrics have them. Not to expensive from memory.
Return to “Tool Shed”
