Skid/side bars..
pradon35s
Skid/side bars..
Post by pradon35s »
Hey all
just wondering, looking at replacing my bent and fcuked side steps with some nice bar work, just wondering wat u guys do with the mounting to the chassis? Straight weld to chassis, bolt to chassis or weld big plates with threaded holes to chassis then bolt to them.. Any info/pics would be mint
cheers guys
UBZ
Re: Skid/side bars..
Post by UBZ »
I had some 6mm plate bent into a C shape to fit over the chases rail, backing 6mm plate and crush tubes in the rail.
Over kill but solid as.
rokhound
Post by rokhound »
I did the same thing, except mine don't bolt through the chassis rails at all, the clamp around it, and I challenge any on here to give their side bars more of a hiding than mine have had :wink: :P
This is how they were on the old truck, and I am using the same bars again, My exo also mounts on these
pradon35s
Post by pradon35s »
Oh yea so then bolted it hence the crush tubes? Cheers for that, any specs on the kind of pipe I'd want to use? Or where to get it cheap
Thanks
pradon35s
Post by pradon35s »
Those pics were exactly wat I'm after cheers heaps mate!
Steve_t647
Post by Steve_t647 »
Look at the chassis rails where you will be mounting them, if they are parallel it could move forward and back if the chassis narrows like Rockhound you will be sweet.
I have seen both types plates drilled and tapped, clamped like Rokhound and directly welded to chassis.
Directly welded (was a poor job and ripped the chassis, drilled and tapped (never moved and they are solid) and I have done similar to Rokhound but 4 bolts 2 on top 2 under the chassis rail with a plate on the other side (I couldn't fold the steel).
Oh and I used tube and got the bends wrong one side is 25mm longer than the other but Sssshhhh don't tell anyone
