air lockers (again)
brakes-shocks-lockers-etc
Which locker would you let your best mate buy?
ARB
19
76%
TJM
3
12%
other
3
12%
Total votes: 25
Heath
air lockers (again)
Post by Heath »
So I see TJM make a locker for the 90 series prado rear end but not for the front (maybe I can use a different model's front??) and ARB make them for both ends. I am toying with locking up my toy and was told TJM are cheaper (havent checked this for myself yet though so it may be wrong...)
So what I am after are the prices (ball park will do) people on here have found and what their experiences (good an bad) are with either brand. why they went with one over the other would be great too.
Which would you recommend it to your best mate or steer them away from basically. :?
Re: air lockers (again)
from aussie 4wd action mag tjm locker $1258 +$265 for the comp harness $69
ARB$1179 -$1342
small pump $175
hi vol pump$345
all price au$
both brands got 10/10 in testing
Heath
Post by Heath »
It would appear that ARB is more popular (by the poll results so far), but I thought they had problems with oil blowing past the seals and back up the airline (and fcuking the compressor). So buggered if I know.
Is it that they have been around longer so have the greater market share so have consumer loyalty?
They are both around the same price, are similar in construction and operation, so what is the reason for one over the other? :?
the test is in issue no 148
Eaton E lockers are $1695
it took 6929 ftlbs of touqe till axle broke twisting the axle 79deg
this was 200ftlbs more than the ARB or the TJM
no compressor to fit and when not turned on you still have your limited slip
Heath
Post by Heath »
Will get a copy of the mag. I already have the compressor fitted and most of the wiring loom so its just the heavy lumps I need (and their switches).
Oh and its got to go in the 90 series prado so that means they have to be avilable (which narrows things down a touch too.)
NJV6
Post by NJV6 »
Heath wrote:It would appear that ARB is more popular (by the poll results so far), but I thought they had problems with oil blowing past the seals and back up the airline (and fcuking the compressor). So buggered if I know.
O ring not installed correctly.
pruggerdore
Post by pruggerdore »
can we have more info on the eaton locker please. what? how? etc
Never had any problems with my ARBs, can flick them in and out at any speed, compressors been reliable but I did get a faulty pressure switch with it and had to replace it?
sure can aussie 4wd action mag issue 148
darinz
Post by darinz »
Exactly. Can't fault a product when it is poor workmanship that is the problem!
