location of fuel screw on my gq
For all Nissan related topics
PigFmr
Post by PigFmr »
location of fuel screw so i can increase fuel on my gq,anybody got a pic or able to tell me plz,
thanks vince
darinz
Re: location of fuel screw on my gq
Post by darinz »
Really if you need to ask where it is you should think really hard before adjusting it.
No photo's but it pretty easy to find.
On the back of the pump there is a screw with a 12mm (maybe 13mm? it has been a while) lock nut. It is probably covered with a safety cap to stop people finding it. But sometimes this cap has already been removed.
To adjust it you will need a stubby flat screw driver and 12mm ring spanner, and the fuel lines are probably in the way as well.
Be warned if you wind it in too far and it over fuels you can get the egt to high and melt the motor. (that's just to cover my ass!)
meece4x4
Post by meece4x4 »
PigFmr wrote:location of fuel screw so i can increase fuel on my gq,anybody got a pic or able to tell me plz,
thanks vince
what Darin said :wink:
Ive just had my Safari in for a full injector pump rebuild, talked to the mechanic about "winding up the fuel" as my Saf isn't turbo'ed and was a bit of a slug and needs all the power i could get out of it for towing, he told me the same thing .. dont just wind up the fuel as it will increase your egt to dangerous levels, anyway they rebuilt the pump to factory specs, timed it again to factory specs and cleaned the injectors... honestly the gain in power was simply amazing, no turbo but will pull up a decent hill in forth gear without bogging down now.
PigFmr
Re: turbo sorted
Post by PigFmr »
thanks sort knew where was anyway, do u really think i wud a wack a turbo without a pyro or boost gauge,thats just asking for trouble turbo fitted goes like cut cat,highest egt was 550 at 150k's wiv manual lock up in, and 120k's on a long hill 500 ,only wound fuel screw from 12 o clock to 4 o'clock,now just got to plumb up intercooler,
corosafari
Post by corosafari »
Looks like good result pigfarmer
Just to be nosey, what turbo system did you fit and what bost you running.
I will be fitting mine in about 3 weeks when home from sea.
CHEERS
PigFmr
turbo sorted
Post by PigFmr »
only running 12lb boost,turbo ct26 off a gt4 with a new custom manifold,trouble is its got to come off again as i broke maifold stud bolt today,blowing now real bad ,
vince
corosafari
Oh that sucks.
I got used Turbo Dynamics/Denco kit with Schwitzer turbo. It also had been running with exhaust leak, thats why not fitted to my truck yet. Have recently planed all manifold faces and turbo exhaust inlet face as this had been damaged from leak. The flange faces have plenty thickness around 12mm, if these are two thin as some types are this can cause distortion snapping studs. Took my manifold outlet studs out to 3/8 BSW, New turbo gasket to source, probably go with one of those scarles ones on tm.
Oh one more question if ok , what EGT guage and how much.
Hope you sort out soon, bloody frustrating aye.
thanks
PigFmr
Post by PigFmr »
egt from company in chch smoked gauge $150,hardest thing to find was a socket for the probe to screw into,my manifold bolt that snapped is the last one at the bulk head,trust it to be the hardest one to get at,
vince
tallsam66
Post by tallsam66 »
I brought my gauge , probe & fittings from here....took about 2 weeks to arrive.
http://www.auberins.com/
Heath
Post by Heath »
Thats where I got mine from, good price and good features too.
corosafari
Cheers guys
What diameter are probes on these, before I make fitting.
thanks
Heath
Post by Heath »
corosafari wrote:Cheers guys
thanks
Pass (sorry), check their website for details, Google "auberins" and check out all the bling. :mrgreen:
tallsam66
Post by tallsam66 »
The fitting usually comes with the guage.Mine is the weld in type.You weld the base to the exhaust then the sensor is securered to the fitting with a threaded nut that presses against a brass ferrule to make it tight.
Heath
Post by Heath »
water temp probe 1/8 NPT
http://www.auberins.com/index.php?main_ ... cts_id=134
EGT probes various threads and fittings. "Four mounting options are offered, 1/8" NPT (most common), weld-in, 1/4" BSP, M8x1 and M10x1."
Just order what you want and he does do Visa.
corosafari
Thanks for above advice.
I have 1/4" fitting to weld in with reduced to 1/8 bsp scew on olive piece. Want to do while onboard as dont have gas set at home you see, cast iron dump pipe will require preheat before welding. This will be about 3mm hole, so can drill or sleeve as required.
Dont worry I wont ask where to drill hole in firewall he he.
thanks again.
darinz
Post by darinz »
The only exhuast manifold gaskets you should use with a turboed TD42 are the factory steel ones. The aftermarket ones will just burn out and it won't make any difference if you plane the head or the manifold.
The best option is to just keep the original ones as they basically don't wear out.
I know of some guys that don't run any gasket at all but that is a pretty extreme case.
GQTROL
Re: turbo sorted
Post by GQTROL »
PigFmr wrote:only running 12lb boost,turbo ct26 off a gt4 with a new custom manifold,trouble is its got to come off again as i broke maifold stud bolt today,blowing now real bad ,
vince
What are the specs of the CT26? i.e. 6 bolt, twin port waste-gated? ceramic wheel? there are a few issues with them FYI.
Was it rear manifold stud closest to firewall?
corosafari
Had heard of that darinz, the aftermarket gasket I was talking about is steel shim type at manifold outlet to turbo inlet. However I did buy 6 aftermarket manifold to head gasket, sintered type but not shim. Am a bit dubious about using them , they were only $28 for set compared to $40 each for original, ouch, get what you pay for, when extractors were fitted recently originals were used, hope they clean up ok.
thanks
darinz wrote:The only exhuast manifold gaskets you should use with a turboed TD42 are the factory steel ones. The aftermarket ones will just burn out and it won't make any difference if you plane the head or the manifold.
corosafari
Just logged on to Auberin Instruments and ordered EGT display unit, bsp thread sensor and oil press sensor, first for me buying like this, bit old school, so easy, too easy its scary. Bloody good value and should be at home before me. So thanks again and to Heath also, sorry havent worked out double quote reply thing yet, think you posted this link for me previously. The units are compact too . cheers
tallsam66 wrote:I brought my gauge , probe & fittings from here....took about 2 weeks to arrive.
PigFmr
Post by PigFmr »
yep replaced all mine with new factory ones,
PigFmr
Re: turbo sorted
Post by PigFmr »
vince
yep firewall just my luck,owned 2 gt4'S so yer knw wot they like ran 20lbs boost for 2 years on 1 of them and gave death for 2 yrs and sold it car still going strong but now only running 16lb boost,
spec all you said apart from mine not ceramic they not the best to have,mines the same they run in
some supra''s and some gt4's and they are smaller than ct26 they put in 80series cruisers
GQTROL
Re: turbo sorted
Post by GQTROL »
PigFmr wrote:yep firewall just my luck,owned 2 gt4'S so yer knw wot they like ran 20lbs boost for 2 years on 1 of them and gave death for 2 yrs and sold it car still going strong but now only running 16lb boost,
Yup, that manifold stud is usually the one to break. I replace all mine whenever the manifold has to come off now.
Atleast you're aware of the pitfalls with them. Initially mine had the ceramic exhaust wheel, unfortunately it broke off the shaft one day. Replaced with a steel wheel and shaft and its been fine since. On the plus side, they do have plenty of scope for upgrade / modifying!
Throw a bigger pump at it and you'll be away!
PigFmr
Post by PigFmr »
have you tried put washers in the wastegate to space it out?? to get more boost,its common on the net read about it a few years ago,have you heard of this ??
vince
GQTROL
Post by GQTROL »
Haven't tried it and I don't see alot of point since most people are still running standard fuel pumps which can't deliver enough fuel to match the increase in air as it is.
Mine would free-boost to about 16psi with the standard compressor wheel, but after changing it to a T04-E wheel with a 52 trim (that was after first trying 48 trim) it would do 18+ quite happily. 20+ it would start getting surge issues and no percievable gain in HP or Nm. This was all with a bigger fuel pump.
corosafari
Re: turbo sorted
Hey GQTROL just out of interest what size are cylinder head to manifold studs, not able to access my vehicle at present but as you say would be good idea to change.
GQTROL
Re: turbo sorted
Post by GQTROL »
corosafari wrote:Hey GQTROL just out of interest what size are cylinder head to manifold studs, not able to access my vehicle at present but as you say would be good idea to change.
Have no idea sorry Coro. I just buy genuine ones from Ni$$an, they're about $4-5 each. Not cheap obviously when you need 12 of them, but much cheaper than trying to remove a broken one.
Return to “Nissan”
