urgent!! Clutch problems
Hi all, Today as I was leaving my boss's I realised the clutch seemed to be weird, couldn't change smooth at all. then realised that 3/4 of the pedal travel was free, and was only getting worse. Only got 2km up the road to the gas station and couldnt disengage clutch to get into gear.
Vehicle is a 93 Vitara, G16a, carb
Thing is I think it is the cable that has gone. would that be right? The thrust bearing has been making noise for the last almost a year. so could that also be it? when i was driving it it wasn't slipping, but when I pushed it at the garage I did smell clutch. also when trying to depress clutch and engine is idling it almost stalls.
any help would be good,
Lincoln
Lincoln
Lubrication Specialist
Lubrication Engineers
Re: urgent!! Clutch problems
that thrust bearings not making a noise now tho is it ?
Two words..........Engine (or Gearbox) Out!!!
Sounds like thrust bearing or cable is fraying inside and jamming up the whole shootin' match.
Bummer Dude
Just as you got Mazda going too.
Lucky you got two cars.
Bummer Dude
it still does, but its a lot quiter than it was before. cant go try it now though as car is at boss's.
oh and Simon the Mazda still isn't quite there, just got to sort clutch out when I get a chance. But yea, thats why I got it. Spare car.
- Rotazuk
Look where the cable goes through the firewall , they have a habbit of cracking and the cable pulls through the firewall a bit . This would give you a slack pedal .
Chris
Chris
Rotazuk wrote:Look where the cable goes through the firewall , they have a habbit of cracking and the cable pulls through the firewall a bit . This would give you a slack pedal .
Chris
Will have a look tomorrow. In my rush to get out of the house this morning I forgot the keys to it.
x2 the firewall thing. I've seen them tear the firewall. Theres a special bolt in there too that can bend also. A lot easier to check all this stuff before taking the gearbox out
how easy is it to change the clutch cable? need to remove anything?
Download a service manual. Heaps on the net for free. Its easy as. Under the truck you have to take it off the clutch lever, I think there's a bracket holding the cable down there on the side of the engine too so undo that and then everything else is up at the firewall end of things. Need to remove the two bolts on the firewall holding the cable - above the master cylinder. I think it just unhooks of the pedal itself but would have to check that.
Havn't done it for a while but I think thats about it. Theres the usual requirement for little asian hands but thats a given
Swamped wrote:Download a service manual. Heaps on the net for free. Its easy as. Under the truck you have to take it off the clutch lever, I think there's a bracket holding the cable down there on the side of the engine too so undo that and then everything else is up at the firewall end of things. Need to remove the two bolts on the firewall holding the cable - above the master cylinder. I think it just unhooks of the pedal itself but would have to check that.
Correct, once it's unbolted at the firewall and gearbox end it just unclips from the pedal. Make sure you use the retainer clip in the engine bay when re-installing it, otherwise it will contact the fanbelt or alternator and rapidly become worn through, necessitating yet another new cable! (First-hand experience
cheers thanks guys. I remembered that I have a Haynes manual here somewhere. At least the boss doesn't mind me leaving the zuk at his place for a while. Few.
wors part was I was so close to getting a locker, and now I have to get a new cable at least, pay for a WoF and reg on my Mazda and prob my mums RUC on her Pajero.
Have you had a chance to look at it yet? I had a similar problem in two escudo's i had. For me it was the bolt that the clutch and brake pedal pivots on. There is no support on the outside and they have a habbit of bending. I replaced mine with a High Tensile bolt 10X180 from memory cut to length.
Yea I had a looked at it. The release bearing must have collapsed, as I replaced cable just in case then after turning the zuk around in the driveway smoke was pouring from the gearbox. i haven't taken it out but will do this weekend hopefully.
The release bearing was making noise for nearly a year so its a miracle it lasted that long anyway. However it didn't make any noise when i put the new cable in, so thats not a good thing. and my old man said it was making a different noise to normal a couple of weeks ago. so its no surprise.
also does any one know any other place that sells Heavy duty clutch kits, other than BNT? one from BnT will cost $415+gst, So just wondering if there is anyone else out there selling them?
ABC (Automotive brake and clutch) Takapuna. Awesome, really know their stuff
Give the guys at BNT a hard time (be cheeky but polite) and ask for trade price. If you dont ask ya dont get. Also mention all the great publicity they will get on here when you sing their praises. Hell even if they only drop 20-30 bucks its better then nothing.
The brake and clutch place on Archers (not sure if they are still there) are okay for prices too (well they were a while ago
I will have to go see ABC then.
and Heath I will see my mate who works at BNT in takapuna, see what he can do for me too. They guy I used to know at Glenfield left there. But hell, $30 isnt bad really, to bad its my locker money i'm spending.
