LJ78 servicing..
LJ78 servicing..
Hi all, recently got myself a LJ78 1kz-te auto. I want to do a full service myself replacing all the fluids. Can anyone please give me some info with regards to whats oil is recommended and grade? transmission oil? diff off etc. it has a factory electric Rear locker does it use other oil?
When i went to Ripco, the guy behind the counter told me that theres 2 types of air filter one is $28 and the other is like $75.
Much appreciated.
On another note, I went to get a price for OME lift kit for $1500 on parts. Is there another brand or kit that others would recommend as $1500 sounds a bit steep... Or is it about right?
Much appreciated.
Re: LJ78 servicing..
Cheers mate..
can anyone tell me where i am suppose to top up the auto transmission oil . i want to change the transmission fluid myself..
through the dipstick hole generally. It pays to replace/ clean filter in sump pan at the same time. price your fluid and ring up for a price on getting it done at trans place. i was surprised to find once it wasn't much dearer to get them to do it as the fluid is so expensive and they would get fluid so cheap in comparison. and you dont end up with an oil stain on the drive way
Ginzu8 wrote:can anyone tell me where i am suppose to top up the auto transmission oil . i want to change the transmission fluid myself..
If you simply drain the sump and replace the fluid, you'll only get about 1/2 of it, fluid sit's in the cooler, pipe's etc.. Take it somewhere that has a trans flush machine, it pump's in new oil through the cooler lines and removes all the old stuff.
It's just more fun in a lada !!
Sweet mate. went to toyota today and they told me to do the same thing so i will go get it priced up..
so is $1500 roughly what you expect to pay to get a lift kit these days.
Wat area u in mate? I'm in chch and my work does transmisson flushes on autos using wynns machine, elf ATF and wynns trans fluid additives for $189 would be more than happy to help u out, that includes ur upto 12L of oil.
In regard to ur lift kit that's quite dear, I have chamberlins 100mm lift springs in my crusher and run rancho adjustable shocks but there are cheaper Raw options available..
Hope this helps, Adam
Ginzu8 wrote:so is $1500 roughly what you expect to pay to get a lift kit these days.
For OME thats about right
hey prado35 thanks for your offer but i am in palmy north. went to my mechanic and they said the transmission oil is sweet.. so will leave it for now , will do the auto transmission cooler first now..
badnuz. yeah thats for the OME kit.. the EFS setup is slightly cheaper.. and the price is just for the kit not installed..
Go in to Appco and ask for Dace. He is on here and sorted me out with a lift kit for my leaf sprung lux with maxitrac gear (which is great btw). Im sure he can sort you something. No point paying 3x more coin for a flash brand when the cheap brands are just as good.
chevrolux wrote:Go in to Appco and ask for Dace. He is on here and sorted me out with a lift kit for my leaf sprung lux with maxitrac gear (which is great btw). Im sure he can sort you something. No point paying 3x more coin for a flash brand when the cheap brands are just as good.
doesnt work there anymore and they dont do maxi trac for coil spung 70's
oh stink. and my bad! will just stick to leaf springs lol
oh well back to square one.. seems like only OME or EFS in NZ
Hey man, I see you have a LWB, but maybe this cheap lift for a SWB will work?
80 series springs into a KZJ71
http://forum.ih8mud.com/70-series-tech/310087-kzj71-lift-80series-springs.html
Interesting.....
Why not go to local spring makers and just get them to make u springs? I got leafs made with 2" lift on my lux for 800 can't imagine coils would be much more? And then go buy a set of Raw shockys that are 2(or however much)" longer than standard shocks..
dont even know if there is any shop in palmy that can make springs and i would assume that custom stuff is normally more expensive..
