Keen to get a egt and water temp gauge sorted out
found these on this site and thought they look good
http://www.auberins.com/
My truck is 24v but the headunit etc is 12v..Do i order the 12v or 24v model
Cheers,Rob
12v or 24 gauges
Re: 12v or 24 gauges
Probably best to decide where behind the dash you are going to get the power from and check if it is 12 or 24v and then order accordingly.
Email him on his site as they may do a 24 volt one (or it may take 24v). I assume they use bugger all so you could take power from the 12v section of the loom. Mine are stealing power from the ciggy lighter socket (only thing is they are on at Acc setting on the ignition) and the dash lights for the dim feature from the dash analogue clock.
