buggy partsFOR SALE safari diffs, ecotec v6..
GQTROL
Re: building a outlaw class comp buggy
Post by GQTROL »
swampa wrote:didnt burst my bubble, the bypass ones are the ones i want, all coilovers to me, need to get each corner weighed then decide on the ones i want, if i do a sweet suspension setup i wont pursue donalds winch and stick with electric, got a figure in my head as to how much i want to throw at suspension, that wont last long
If you end up going with King or Fox, some good deals can be found at http://www.shop.downsouthmotorsports.com/main.sc Few of the guys have bought gear from Downsouth now and Sonny has some competative prices, but you can still wave goodbye to $6-10K easily enough.
Using the biggest shock body you can (i.e. 2.5" or 3") for the given travel (i.e. 14", 16", 18") you need is the way to go. Benefit of by-passes is you can get the position of the 2nd compression tube fitted where you want at the factory and setup the last inch or two of compression to act as a bumpstop, so along with your standalone bumpstop it can take some big hits if you forget to take your foot off the gas.
swampa
Post by swampa »
right, made some progress, had a rover v8, hilux 5speed , transfer case etc all tacked in, then decided it wasnt going to cut the mustard, so over the weekend it's coming out and a builder i work with is taking it in exchange for a few days labour, hilux diffs it was set up for have come out and a safari rear diff has gone in, still looking for a front one, 4 linked the rear, lower safari arms arn now the top arms and the top safari arms are now lengthened to 1000mm and are the lower arms, NOW the engine, looking for a chev 454 or larger, turbo 400 trans and safari transfer case, not shagging around with modern engines in this, gonna build a crowd pleaser, also have lengthed the wheelbase to 2600
darinz
Post by darinz »
swampa wrote:right, made some progress, had a rover v8, hilux 5speed , transfer case etc all tacked in, then decided it wasnt going to cut the mustard, so over the weekend it's coming out and a builder i work with is taking it in exchange for a few days labour, hilux diffs it was set up for have come out and a safari rear diff has gone in, still looking for a front one, 4 linked the rear, lower safari arms arn now the top arms and the top safari arms are now lengthened to 1000mm and are the lower arms, NOW the engine, looking for a chev 454 or larger, turbo 400 trans and safari transfer case, not shagging around with modern engines in this, gonna build a crowd pleaser, also have lengthed the wheelbase to 2600
You do realise that with a modern engine you'll get more power (and reliablity) for the same money. And if done properly a modern Jap V8 sounds like a BB anyway. So you can have a lighter, more reliable engine with the same HP for the same money! But you will have some electronics and some don't like that.
The other thing is if you are fitting a turbo 400 why don't you go with an NP205 (or 3 can't remember which) as it bolts on and is stronger? Just not as common.
Just a few ideas.
swampa
Post by swampa »
yip, thought about pulling the engine and drivetrain out of my lux, jap, and aussie v8's are the way to go, but i have this idea in my head, 454 stroked to 572, safari diffs or larger, either safari auto and transfer case , hadnt thought about the NP205, will definitely look into that, if on you tube type in tim cameron , this rig in my opinion is the best in the world, it's INSANE!!!!!!!! i know it's impractical and too big, but i dont care,
DieselBoy
Post by DieselBoy »
Why not stick with toyota diff's??
60 series would be the go.
That way you can get all the good off the shelf bits like cromolly axles and CV's etc etc.
There are very limited options for Nissan front ends, and even less for Nissan rear ends!!!!
At the end of the day, 9" diff is by enlarge, the same as the next, Toyota or Nissan. Its the good stuff that you can buy for em to beef them up to take the huge horse power that should be the decider!!!!
swampa
Post by swampa »
already got safari diff in the rear, gonna take the front diff out of my safari and chuck that in, i could spend an eternity trying to find the strongest readily available gear in nz at a reasonable price and get nothing done
DieselBoy
Post by DieselBoy »
swampa wrote:already got safari diff in the rear, gonna take the front diff out of my safari and chuck that in, i could spend an eternity trying to find the strongest readily available gear in nz at a reasonable price and get nothing done
If its out of a GQ safari, and your putting the front diff into it, plus your running a 527 and big tyres, you will be able to blow CV's on demand!!!!! :lol: :lol:
At the very least source a GU Patrol front diff!!!!
swampa
Post by swampa »
trying to, havent found 1 yet, around $2000, would rather put the gq in then buy the cal offroad cv's etc, for a bit over $2000, they gaurantee their gear up to 42" tyres
cool__bananas
Post by cool__bananas »
Jafa
Post by Jafa »
swampa wrote:yip, thought about pulling the engine and drivetrain out of my lux, jap, and aussie v8's are the way to go, but i have this idea in my head, 454 stroked to 572, safari diffs or larger, either safari auto and transfer case , hadnt thought about the NP205, will definitely look into that, if on you tube type in tim cameron , this rig in my opinion is the best in the world, it's INSANE!!!!!!!! i know it's impractical and too big, but i dont care,
Hahaha your a nutta!, I love it!
Heres a pic of what Karam wants to build, this is Tim camerons "Fat Lady"
021 273 9942
jafa@inspire.net.nz
swampa
Post by swampa »
thanks for that, their was a set of 404 diffs in oz last week, the guy wants $3500au for them got his number here, dont know about freight
Jafa
Post by Jafa »
swampa wrote:thanks for that, their was a set of 404 diffs in oz last week, the guy wants $3500au for them got his number here, dont know about freight
And thats before you spend heaps with an engineer strengthening the portal boxes, getting rid of the torque tubes, modifying the pinions.....blah blah blah :roll:
021 273 9942
jafa@inspire.net.nz
swampa
Post by swampa »
would rather stick with plain ordinary stuff i can walk to the shop and buy off the shelf, k.i.s.s.!!!
swampa
Post by swampa »
swampa
Post by swampa »
swampa
Re: building a outlaw class comp buggy, for sale
Post by swampa »
right, glen just came and showed me how to do pics.
it started off with hilux diffs, they are gone, these are gq items,
3 link front, 2 arms 1 side and 1 on the other, long ones are just over 1100mm,
rear is a 4 link with double triangulation bottom arms about 1100mm
tyres on here are 40" good year wranglers, which will be replaced with bigger ones by the end of the year,
the flex in the front is about at 70% as the diff was tacked to the frame so we could set ride hight
with 40's the top of the cage is under 6feet high
that front wheel from the very bottom is about 1200mm off the ground, still miles to go, just that the garage wasnt high enough
still setting things up to decide on travel, looking for around 18" travel, what you see there is using 14"
mainly checking front flex to see how everything works, making sure there is no binding etc...
the rear has crazy travel.
over and out[url][/url]
turoa
Pyro Junior
Post by turoa »
are you going hydro steer?
swampa
Post by swampa »
for sure, tucked in behind diff, changed it to left hand hook yesterday aswell
seen the howe setups in oz, bit pricey though, should be able to sort out some 2nd hand gear somewhere locally
darinz
Post by darinz »
swampa wrote:trying to, havent found 1 yet, around $2000, would rather put the gq in then buy the cal offroad cv's etc, for a bit over $2000, they gaurantee their gear up to 42" tyres
And if you heard the problems people are starting to have with GQ cromo cv's you wouldn't be wasting your money on them. A guy I know is working on a GQ cv replacement that uses a common cromo CV from the US. Same factory as Cal CV but about 1/3 the price. eg about the same as genuine CVs. No life time guarantee as that is a waste of time anyway. The other thing this will do is provide a kit to change to Toyota free wheel hubs that are a shit load stronger.
These will be stronger than GU CV's and are stronger in the stub axle which is the next thing to break when you go really big eg over 37.
PM me if you're keen and I'll start getting list together to get them cheaper.
flyingbrick
Post by flyingbrick »
Darin- are these still happening?
swampa
Re: building a outlaw class comp buggy, FOR SALE
Post by swampa »
ive lost interest, needs a heap of work to finish off, has commy v6 with hilux transfer case , gq safari diffs, no tyres.
make me an offer txt me 0274164667, could be rolled onto transporter but would prefer local so you could see whats left
Engineer
Re: building a outlaw class comp buggy FOR SALE OFFERS
Post by Engineer »
if i hadnt just bought a house i would have made an offer.
its a shame youve lost interest!
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
You Get That
Post by You Get That »
Hey mate has sold yet?
Addicted to suzukis....
swampa
Post by swampa »
just sitting in a mates shed in otautau, im not selling any parts off it and it doesnt have any big tyres either, i havent done any work on it in over a year as i have gone to s.i.t
You Get That
Im from otautau :wink:
Has it still got lockers in the axles? what about the suspension.
Can it run? Has it got the hydrolic winch?
swampa
Post by swampa »
you are miles off the track, has got gq diffs, never had lockers, never put any winch on it, probably would run with a fuel tank and radiator, would be easier for you to view it, that way you would see what stage it is at
swampa
Post by swampa »
i want this thing gone, needs heaps of work, no lockers or tyres, must pick up, $2000
0274164667
no swaps
You Get That
Are you talking about the orange hilux?
Saw someone moveing that around otautau sunday thing looked MEAN 8)
swampa
Post by swampa »
that ones long gone
swampa
buggy FOR SALE OFFERS will seperate parts
Post by swampa »
3.8 ecotec v6, holden auto and lux transfer case, offers over $1000
Diffs, both wont seperate, $700
chassis, $500
You must pick up
