reverse spotlights
snork
reverse spotlights
Post by snork »
Can a spotlight be wired to a switch so the driver can operate it when ever he wants to, or does it have to be wired into the reversing light loom?
Cant see a bloody thing while reversing.
SV1K
Site Admin
Re: reverse spotlights
Post by SV1K »
Mine is on a switch and my reverse lights don't work anyways! Never had an issue with WOF either..
8)
wopass
Post by wopass »
any white lights to the rear must only be opperated by the reversing light switch. if it is manualy opperable by the driver when not in reverse it is a dangerous fitting and will fail a wof...if the wof guy notices :wink:
DieselBoy
Post by DieselBoy »
wopass wrote:any white lights to the rear must only be opperated by the reversing light switch. if it is manualy opperable by the driver when not in reverse it is a dangerous fitting and will fail a wof...if the wof guy notices :wink:
Have it opperated by a switch, but also opperated by the reverse switch, best of both worlds :lol:
pruggerdore
Post by pruggerdore »
Wire it for both, wof man wont notice or care. just dont mess up and leave it on on the road. put switch where you cant hit it by accident. Wire into the revrse light circuit with a relay
kiwipete
Post by kiwipete »
Sorry but you are wrong. You can if they are classed as "working lights". There is a clause in the regs that these "working lights" are not covered by a WOF. They are lights used to light, forwards, sideways and rear of a vehicle.
How do I know this, I have had a look with my WOF guy through the regs and we came across this. He now knows my set-up and has no issues with he lighting.
Ph 0212078472
GotFlex
Post by GotFlex »
i have mine on a switch, its good for when some idiot sits up my ars at night, one flick of the switch and hell do they back off quick
blulux
Post by blulux »
hello you can also wire then so they cant come if the head lights are running, this will pass a wof
Scott
1991 Hilux ,solid front axle ,3.0 2jzge,crane
petefj40
Ms Daisy
Post by petefj40 »
GotFlex wrote:i have mine on a switch, its good for when some idiot sits up my ars at night, one flick of the switch and hell do they back off quick
:lol:
Ditto.
Mines on a switch to.
Return to “Tool Shed”
