Hilux Dual Transfer Case Adapters F/S
Anything to do with upgrading that transmission / powerplant.
Moderator: Vendors
suzolla
Post by suzolla »
Hi,
I have got some trailgear dual transfer case parts as below.
Costs are plus freight from Hamilton.
Trail-Creeper™ Dual Transfer Case Adapter 21 Spline $550
Trail-Creeper™ Dual Transfer Case Adapter 23 Spline $550
23 Spline Input Gear $250
Creepy™ Twin T-Case Shifter Forward Shift $225
Creepy™ Twin T-Case Shifter Top Shift $225
PM me if interested
Thank You
Tim
suzolla
Re: Hilux Dual Transfer Case Adapters F/S
Post by suzolla »
Bump
Tim
suzolla
Post by suzolla »
Bump
See first post
Tim
suzolla
Post by suzolla »
Hi,
Bump
See first post, PM if interested.
Tim
T-Boon
Post by T-Boon »
so what exactly do these fit on ?
Do you have some more info ?
To Boon or not to Boon.
suzolla
Post by suzolla »
Hi,
They fit on Toyota Hilux gear-driven transfer case, enables you to put 2 together to get really low gearing.
See http://www.trail-gear.com/dual-adapter
Tim
rokhound
Post by rokhound »
If you are really into technical 4wding (ie not just bush bashing or mud plugging) this is one of the best mods you will ever make to a lux :wink:
suzolla
Post by suzolla »
Along with lockers
Tim
T-Boon
Post by T-Boon »
ah, makes sence. can you chose to only use one transfer? or is it both or 4wd high ?
[EDIT] ah, so you get 2 transfer leavers, e.g you have to cut a hole in your floor and sus out a gearbox boot etc ?
suzolla
Post by suzolla »
Hi,
Bump
Tim
suzolla
Post by suzolla »
Hi,
Bump
Tim
suzolla
Post by suzolla »
Hi,
Bump
Tim
suzolla
Post by suzolla »
Hi,
Bump
Tim
suzolla
Post by suzolla »
Hi,
Bump
Tim
suzolla
Post by suzolla »
Hi,
Bump
Tim
flyingbrick
Post by flyingbrick »
any for nissan?
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump.
See first post
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
See first post.
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
See first post.
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
See first post. Prices dropped a little bit
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
PM me if interested
Tim
suzolla
Post by suzolla »
Bump,
See first post.
PM me if interested
Tim
Return to “Motor Transmissions and T-Case ”
