413 engine into 410
For all Suzuki related topics
unadunted
413 engine into 410
Post by unadunted »
Gidday guys. Will a 413 motor and box drop into a 410 without any drama? engine mounts, shafts etc the same?? Ta
UBZ
Re: 413 engine into 410
Post by UBZ »
No , no and no.
Engine mounts are in different locations ,tunnel needs to be moded to fit the five speed gearbox, 410 transfer case has a different bolt pattern to 413.
What is wrong with the 970cc?
suzookyman
Post by suzookyman »
UBZ wrote:No , no and no.
:lol: :lol: you funny fulla
unadunted
Post by unadunted »
Thanx. I have a 410 that had a swift GTI motor in it but was removed b4 I got it, therefore the bracket on the chasis have been changed for that. I can get a G13b motor and box but have 410 ute t/box. U know the drill, trying to put together a million dollar truck on a shoestring. :(
Heath
Post by Heath »
:P We all start with small shoe string but they all seem to stretch. :mrgreen: Good luck with the build.
Rotazuk
Post by Rotazuk »
Let me guess , it was Pink :)
To fit the 410 t/case into a 413 you can either change the input flange on the t/case or change the jack shaft uj end . I am pretty sure the uj's are the same between the 410 and 413 ( I know a 413 vitara and swift are all the same ) . I think thats what was in there before , a 410 t/case and a modified Jack shaft . If it was a pink 410 a g13 should bolt in as the gti block had factory 413 mounts on it .
Chris
Heath
Post by Heath »
Rotazuk wrote:Let me guess , it was Pink :)
Chris
Has some one started resurrecting the lil piggy? :shock:
unadunted
Post by unadunted »
Yes, yes and yes; it's pink and been in the shed for too long.
How much modification required to the trans tunnel? Heavy hammer or cut and weld?
Ta
Rotazuk
Post by Rotazuk »
UBZ wrote:,tunnel needs to be moded to fit the five speed gearbox
This was running a 5sp gearbox , no modification to the tunnel will be required . you will see the shifter hole has been cut out a bit more , either fore or aft , can't remember .
Chris
unadunted
Post by unadunted »
Great, I'm running out of excuses now :) so time to get on with it. Just need some shocks and some time.
UBZ
Post by UBZ »
Bring back lil piggy. :mrgreen:
But it has to stay rank pink and you have a lot to live up to :roll: :lol: :lol:
lilpigzuk
Tiger Balm
Post by lilpigzuk »
UBZ wrote:Bring back lil piggy. :mrgreen:
Is that a beaten patrol I see in the back ground :lol: :mrgreen:
Tunnel was cut (hacked) to clear 5 speed gearstick.
This could be an embarrassing thread, It was originally built on less than a budget
:oops:
and the rank pink was toyota forkhoist red in a can.... that was obselete.....Image
UBZ
Post by UBZ »
lilpigzuk wrote:It was originally built on less than a budget
But still gave V8 crusiers a run for thier money
Click for Vid :wink:
lincooln
Post by lincooln »
I remember when I was a kid watching that thing. :D Maybe thats why i like zuks :wink: :lol:
Lubrication Specialist
Lubrication Engineers
unadunted
Post by unadunted »
Maybe a change in plan :shock: Found someone with 3x vitara/escudo motors sooo.... Can anyone tell me which is the best model for offroad in a 410: 8 vs 16 valve, fuel injected vs carb, ... Any advise appreciated thanx. :)
Heath
Post by Heath »
unadunted wrote:Maybe a change in plan :shock: Found someone with 3x vitara/escudo motors sooo.... Can anyone tell me which is the best model for offroad in a 410: 8 vs 16 valve, fuel injected vs carb, ... Any advise appreciated thanx. :)
8V better torque then 16v, but 16v has better power I'm told. Carb is easier (use std fuel pump) than injected, but not as good on angles due to position of float in the fuel bowls I believe (prone to flooding and stalling).
lincooln
Post by lincooln »
and you can get a cam regrind done to a just about mild and it works best on the 16v. fair rockets. and its only about 150 bucks.
i have found the carb to be great.ot a problem at all with it.
Return to “Suzuki”
