Sadam_Husain wrote:Bulletproof wrote:Hi Marty
Dont you have a solid 12mm piece of vertical steel welded on to strengthen the spring Perches ?
My perches did that also so I beefed them up.
Cheers Richard
Yeah Howie made some new spring perches for it out of some box sextion with the ends capped off to strengthen them up... not sure what will bend or break next? I've got a pic somewhere but it takes hours to find it on photobucket on my dialup connection![]()
I think Marty is talking about these photo's
Before Howie got it...
After Howie sorted it....
You see the disconnected upper control rod and underneath is the fuel tank and when the left wheel moves up into the guard the right wheel moves down when going through a rut or hole, when it moves down the upper control arm hits the tank and restricts articulation. as you see my problem. so hence wanting to move arm out of the way and having a on top of diff setup similar to a 4 point system from trailgear
