vomitron....
niblik
Post by niblik »
start up vid with manifold on etc.. courtesy of steve, cheers guy..
http://www.4wdtv.co.nz/node/405
niblik
vomitron..
Post by niblik »
****old thread dig up warning****
got 4 of these..
bought vomitron home from storage..
put some greasy nipples onto hubs..
longer studs and spacers to take flip arm steer etc.. thanks kbjj..
to look like this..
helpy helper..
front rover diff out..
then rear fell out..
new front end mocked up..
decided to not worry about 4 wheel drive.. doin it HOVERTRON styles..
SMOKEY
Re: P.O.S build..
Post by SMOKEY »
I know it's not hard to do Nibbz but you have got me :? , :o , where and why is this heading :shock: :?: :?: . I be thinking :roll: , Mudplug coming up, MUD TAHS, FEE 8, lots of NOISE, BROWN FACE 8) , WHITE TEETH :D , :idea: :arrow: ,
NIBBY HAVING FUN :?: :?: :?:
FITZY.
Mongoose
Re: P.O.S build..
Post by Mongoose »
that's the wrong word after "Land"....
rokhound
Re: P.O.S build..
Post by rokhound »
SMOKEY wrote: where and why is this heading :shock: :?: :?: . I be thinking :roll: , Mudplug coming up, MUD TAHS, FEE 8, lots of NOISE, BROWN FACE 8) , WHITE TEETH :D , :idea: :arrow: ,
FITZY.
You have it in one Fitzy, now if he can make it, you really have no excuse do you? So we will see smokey there as well won't we? :wink: :P
vvilly
Re: P.O.S build..
Post by vvilly »
mmmm are they Nissan bolts
niblik
Re: P.O.S build..
Post by niblik »
front end fully rebuilt with new seals and bearings throughout. running a 4.3...
vvilly wrote:are they Nissan bolts
oh, and jeremy and jase.... Image
:mrgreen:
niblik
Re: P.O.S build..
Post by niblik »
i farkin hate diff heads.. put a locker in the rear.. 4.3's now rather than a 4.5..
had to drill new locations on spring perches to locate the diff further back as i was paranoid the new tyres might not clear the mufflers, so drilled perches to locate front diff more forward.. turns out it wasnt needed as much..
put it under ole vomitron.. not sittin on the diffs yet as need to sort ubolts... will drop front by approx 3 inches and rear by approx oober....
so both diffs, front ifs'd, under.. (still sittin on axle stands...)
and due to ifs hub swap and ifs lux rear diff, better width track is acheived..
ClassicCruiserSpares
Re: P.O.S build..
Looking good there fulla, keep up the good work.
rokhound
Re: P.O.S build..
Post by rokhound »
Rock on :P
rangimotors
Re: P.O.S build..
Post by rangimotors »
what is the blue gasket/sealer? i use 3 bond for important stuff or the red high temp stuff for general things but haven't found the bling blue stuff..
Build looks great by the way..
kbjj
Re: P.O.S build..
Post by kbjj »
[quote="rangimotors"]what is the blue gasket/sealer? i use 3 bond for important stuff or the red high temp stuff for general things but haven't found the bling blue stuff..
quote]
Its not Blue Shit, tastes different. :shock:
petefj40
Ms Daisy
Re: P.O.S build..
Post by petefj40 »
Good to see this build moving in leaps and bounds nibs.
Be even better to see it in action at Sheffield!! :wink:
That will be your first event were you're actually in the drivers seat, not passenger seat? :shock:
Keep the updates coming mate.
niblik
Re: P.O.S build..
Post by niblik »
rangimotors wrote:what is the blue gasket/sealer?
exactly that.. blue gasket sealer stuff.. :wink:
sorta like this..
niblik
Re: P.O.S build..
Post by niblik »
alternator issue sorted thanks jezza.. big fuse inline from alt to ignition..
ubolts all sorted with spring plates and sittin on all 4's..
took stoopid mistake of cross over steer and longer studs off and put standard 40 series steering arms on because with a little adjustment from the tie rod ends, the standard 40 tierod will be the perfect addition between the hubs. this way i'll use the 40's tie rod end to link up to the steering box..
petefj40
Ms Daisy
Re: P.O.S build..
Post by petefj40 »
Sitting very differently to how you first got it nibs.
Looking good!
oldyella
Re: P.O.S build..
Post by oldyella »
I'm liking how the LR is sitting compared to when you got it. Much more stable looking... Keep up the good work!
rokhound
Re: P.O.S build..
Post by rokhound »
oldyella wrote: Much more stable
Unlike it's owner :mrgreen: :mrgreen: :mrgreen: :mrgreen:
niblik
Re: P.O.S build..
Post by niblik »
and the rovers a pos, unlike its owner.. *fingers..* :mrgreen:
MNC
Re: P.O.S build..
Post by MNC »
niblik wrote:alternator issue sorted thanks jezza.. big fuse inline from alt to ignition..
Looking good Nibs :wink:
Smurf
Re: P.O.S build..
Post by Smurf »
Sweet rims and tyres, Should go awesome at Sheffield :lol: :lol: :lol:
niblik
Re: P.O.S build..
Post by niblik »
thanks mnc.. :P
rear shocks in, rear brakes hooked up, breather on rear diff, fire extinguisher mounted, front guards cut and reshaped, front tie rod adjusted and in, drivers seat bolted up, driveshafts made (thanks jeremy!!) for front and rear, new radiator shroud made up cos last unit would not suffice. the fans i'm goin to use would be too close to the engine and need the extra depth and width to utilise all the radiator fins.. calipers milled a tad to be able to centre them on the front discs..
driveshafts on. front calipers fitted and hooked up.
Re: P.O.S build..
Keep up the good work this builds really moving along, itll be ready in no time.
wopass
Re: P.O.S build..
Post by wopass »
niblik wrote:thanks mnc.. :P
rear shocks in.
up the right way i hope :mrgreen:
niblik
Re: P.O.S build..
Post by niblik »
doesnt matter wop.. this things got all the flex of a skateboard on viagra in rigor mortis.. :P :mrgreen:
wopass
Re: P.O.S build..
Post by wopass »
niblik wrote:doesnt matter wop.. this things got all the flex of a skateboard on viagra in rigor mortis.. :P :mrgreen:
hahhahah
PR
In the crap again
Re: P.O.S build..
Post by PR »
niblik wrote:this things got all the flex of a skateboard on viagra in rigor mortis
Now theres a sign for the side of it :lol: :lol:
(021) 02388443
vvilly
Re: P.O.S build..
Post by vvilly »
well it shouldn't end up on its side then Jase aye
niblik
Re: P.O.S build..
Post by niblik »
just a quick old pic of the sua plates and shock mounts but! ya can see the new driveshaft in there.....
with much thanks to rexina, got new wiper blades and bit on..
ifs hub swap done..
some new bonnet latches cos the last ones had perished..
fire extinguisher mounted between seats in easy reach from either side of the vehicle..
nibified the rear guards at the front of them a little.. cut and folded to clear front of rear tyres..
ya can sort of see it before in this pic....
after..
lower seat belt mount.. gets a bit tight for room..
back of mount to chassis.. well, better than nothing..
centre seatbelt mounts run throught to chassis..
and above....
so both seats belted up.. it is a good thing... with the ride this thing has, i could get thrown out..
got a bit of fanny action this morn too..
lilpigzuk
Tiger Balm
Re: P.O.S build..
Post by lilpigzuk »
nice work gaysian 8) So you still have a shit ride with the parabolocks??!! Should be better than the 10 or more leaved standard leaves :?
