So after tossing up the price of rebuilding up the 2.4 i decided to put my $ more wisely into a 1KZ-TE and R151 gearbox from a rolled bowled and arse-holed KZN130 surf. Worked out really well as i got the entire engine loom from the batteries to the taillights, also gas cut the engine mounts from the chassis
Ive been reading these boards and see alot of people asking about 1KZ conversions so ill go into a bit more detail for people, but feel free to ask anything!
So the conversion started, Out with the 2.4, ground off the old 2.4 engine mounts and dummy fitted the 1KZ with gearbox attached, bolted the gearbox cross-member in place and moved the 1KZ mounts to the appropriate place on the chassis and tack welded in place, Pulled the motor back out and had mounts welded professionally. So engine back in. Drive line wise everything bolted up, had to trim the gearbox tunnel abit for the further forward shifters
Sadly LN61's are IFS (found this out after id made the deal and traveled to wellington to pick it up) however did make it easier as the engine didn't need any sump modification as kZN130's are IFS to
The wiring was a bit of a mission, but i enjoy a challenge and tackled it, cut out all the unnecessary wires in the loom untill it was just the bear basics to run the Engine ECU and 4x4 gearbox ECU, Swapped the KZN130 dashboard into the truck to so a little bit of swapping there to with indicators, 4x4 lights, backdoor lights blah blah blah
Overall the conversion was easy (even more so if you went mechanical injection) Even the power-steering lines bolted up, Little things like custom radiator and heater hoses, Converting alternator to internally regulated. Viscus fan all fitted in with the factory LN61 radiator and shroud.
Engine runs really well but im in the process now of custom making a water to air intercooler setup for it, More pics and details later i guess
Also looking at a front bar setup and body lifts, it looks to much like a road truck
Plan is to get it out in the mud set up a bed in the back and be the tow wagon. Sweet
