L200 sitting on bump stops almost ?
wildplumdx
was under my truck the other day measuring for a body lift bolt length etc and noticed my truck only sits 10mm if that off the bump stops !? what the hells up with that ? someone lowered it or just sagged in the torsions or something ? whats the factory height ? better yet what can i take it too ? my guess 50mm of excess in the shocks to allow for lift sound alright ? if that makes any sense.
Re: L200 sitting on bump stops almost ?
if it's the front end your talking about that standard with a irs front end
wildplumdx
oh ok whats irs stand for and yes front end
IRS stands for Independant Rear Suspension....
wildplumdx
thats what i thought but i thought maybe its something else for the front
oh for ffs ifs then inder front suspen
wildplumdx
yep my b2.6 was the same , most ifs trucks the same,quote from mazda'' it has 1'' 1/2 downward travel at the hub''
which is a fat lot of good for offroad. the new utes out there ford. mazda mitzi nissan you'll be lucky to slide your finger between the arm an bump stop.wind up the torsions and live with it
