deciding on a motor help me make a decision
i'm deciding on a engine and need some help deciding.
i want a reliable engine that won't let me down and won't miss a beat. i want plenty of power. i like the 1kz-te but its so unreliable! so im thinking a 1hz possibly what do u all think
- ClassicCruiserSpares
- Sausage Shack
Re: deciding on a motor help me make a decision
More info? what sort of truck is it going into? what size tyres are you running?
95 surf...
dont fk around and drop an LS7 in it
http://www.jegs.com/i/GM%20Performance/ ... /-1?CT=999
- rangimotors
13bt's are pretty good. Huge though could be a tight fit
For a reliable engine that has plenty of power and won't let you down you can't go past a GAS TURBINE ex Air NewZealand, about the only one that I can think of that ticks all your box's,
HOW LONG WAS THAT PIECE OF STRING,
FITZY.
FITZY.
yeh i think 13bt are tough as but i wanted something with a bit more grunt. it will be a landcruiser 95ish swb. i don't mind the cost just want reliabilty as well as power. if i go turbo im screwing my odds with reliabilty right??
- mudlva
350 sb chev on love gas
simple strong reliable and you can build the motor to as much HP as you want
no computers, no management systems, no turbos and a shit load of aftermarket bits around
- Sausage Shack
If its going in a cruiser get a 14bt there 3.7 turbo ive got one in my 70 series and its got way more grunt and torque than a 13bt, and my one has never given me any troubles.
- Sadam_Husain
- Angry bird
Dont listen to all those diesel people mate... they mean well but we all know there wrong... you know you want to do it
mudlva wrote:350 sb chev on love gas
wopass wrote:95 surf...
Will the running gear on a 95 surf handle the torque of a V8?
What about an LS1 or Lexus V8?
When it's, "wired" up well or correctly there's nothing wrong with the fuel management on them. Reliable AS!
And if you run it everyday it won't suck through the gas like the old school V8's do.
i'm a diesel man sorry i like v8's but not my cup of tea. ok guys tell me about diesel injector cleaners. can it burn injectors and block them as im starting to believe this is my problem
In order for some advise it may pay to spill all
What sort of vehicle is it
What are the current problems with it
What do you use the vehicle for
How much Doe Rae Me do you want to throw at it
Is it your daily driver etc,etc,etc
read my other post
i suggest you drop this into it
toyota 5 litre V12
http://www.trademe.co.nz/Trade-Me-Motors/Car-parts-accessories/Toyota/Engines/auction-312553031.htm
toyota 5 litre V12
my 4wd is not a truck
simmo wrote:read my other post
Stick with the 1 kz.
Just get a good one
They are a pretty good motor and you know it's gunna bolt straight in.
My 10c worth anyway.
its just causing me trouble and i thought id get more out of a 1hz-t
- IcedJohnno
- Trailer Trash
mylux wrote:simmo wrote:read my other post
Stick with the 1 kz.![]()
Just get a good one
They are a pretty good motor and you know it's gunna bolt straight in.![]()
As above
The 1KZ is a great motor and very reliable other than the usual head issues, if you have a lead foot or lug the motor.
I have done 140 ooo ks in mine, now reading 210K. At 150k I replaced the head, however if I had ripped the EGR system off it when I got it, it is likely that this would not have been an issue.
I also am partial to towing trailers at 140ks!
Plenty of torque, the turbo spools up nice and low which suits off-roading and they are reasonably economical. With a few weee ee tweaks they are an even match with the 1UZ in terms of power & torque. This has been proven in jet boats that are twins other than the motor.
mercutio wrote:i suggest you drop this into it
toyota 5 litre V12![]()
nice motor but im a diesel fan haha
Theres nothing wrong with the 1kz-te mate as long as you look after it it will look after you. For their size they have awesome power and torque, and todays turbos are rather reliable.
Eventually i will be replacing my 2l-te with a 1kz-te intercooled engine when i have $$$ and time
1992 LJ71 Prado 2 Inch lift 33" Buckshot Mudder's
Snorkel, Front ARB bar and Winch
well if your so set on the diesel plant i only have one word...
DURAMAX
DURAMAX
- skid
- Tyre Man
wopass wrote:well if your so set on the diesel plant i only have one word...
DURAMAX
go buy that lotto ticket
http://www.trademe.co.nz/Trade-Me-Motor ... 935538.htm
mmmmmmmmmmm I want
