Cut a long story short ended up towing the trailer out with rope and then the tranzit van with me mums car. Had a very long strop to the landrover from the tranzit van and then a very long rope from my mums car to the tranzit van. Finally got the landy to the trailer and winched it on and then proceeded to drive up the shingle driveway still being towed by me mum. Slowly the van and trailer started to move forwards. Thank god for mums and GF's that can drive big transit vans, I say. 8O
After two years in a barn:
Rats had eaten everything plastic!
Rat crap everywhere!!
Battery fluid completely gone! -> New Battery, old one being tested
Clutch rusted to flywheel. Freed by acclerating and de-acclerating with clutch in. Engine started, First turned motor over to let oil pressure build up or flow through. Then it took about 3 times with glow plugs on.
Rats had eaten through the diff breather for front axle and the rest of it nearly rapped itself round the fan belt!!
Diesel mysteriously disapperead just like the clutch fluid.
Tyres still inflated at 35psi!
Steering is very tight and heavy.
Bit of work coming up. I think I might take it for a WOF to see what needs fixing.
Mike
