i am after a ball joint flip for my 1993 swb pajero
kyle1234
Post by kyle1234 »
i have a 1993 swb 3.0 petrol pajero and am wanting to do a lift on it, any tips and pointers thanks.
adimw2
Re: i am after a ball joint flip for my 1993 swb pajero
Post by adimw2 »
are you looking to just fit bigger tires? or get more ground clearance... because a body lift is easier and might be all that you need.
Current ride: 2002 L6 4.0 Jeep Wrangler
Lynx
Post by Lynx »
Ya gotta watch out with bodylifts aye, seen a few broken body mounts due to bodylifts.
Cheers Daniel
kyle1234
Post by kyle1234 »
adimw2 wrote:are you looking to just fit bigger tires? or get more ground clearance... because a body lift is easier and might be all that you need.
just after the ground clearand already have 33x13.5 on it, where would a get a ball joint flip from?
kyle1234
Post by kyle1234 »
NJV6
Post by NJV6 »
You don't 'get' a ball joint flip. Do a search and you will find, you flip your ball joint. not extra parts needed.
And it won't give you more ground clearance.
Fergy
Post by Fergy »
If you have money to burn mate, this is for you.
http://www.trademe.co.nz/Browse/Listing.aspx?id=313535487
Otherwise, its easy enough to do it yourself :) just check out this thread.
http://www.offroadexpress.co.nz/Forums/viewtopic.php?t=2159
Pretty sure NJV6 did it in here somewhere
Return to “Mitsubishi”
